April 22, 2010, 11:34 |
RGP file for liquid air
Rep Power: 17 |
Hello everybody,
I need to simulate the liquid turbine, and the working fluid is liquid air. The pressure range is 0.1Mpa to 5Mpa and temperature reach from 90K to 100k- I'm dealing with a cryogenic application. How can I define this material? From the doc, we know cfx can define the liquid phase materials, but the doc explains not clearly. I just know when you define the liquid material you need to set the parameter RGP Liquid Properties = Subcooled in the CCL for the liquid material definition. But, in the example of the organization of .rgp file, i don't know how and where to fill the subcooled liquid tables. Besides, is it necessary to fill the "superheat" tables in the definition of a liquid material? Thanks a lot! Last edited by eis; April 22, 2010 at 22:39. |
rgp liquid air |
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 09:10 |
OpenFOAM 15 and openSUSE 111 paraview works OK | alberto | OpenFOAM | 10 | March 6, 2009 06:52 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 18:33 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
