CFX pressure in Simulations problem
Old   April 13, 2010, 19:14
Default CFX pressure in Simulations problem
chris
nasdak is on a distinguished road
Hi
I have a problem with appling the CFX pressure in the Simulations. One of the condition to use CFX pressure in Simulations is (from help):
"The location of the ANSYS CFX boundary (with respect to the global Cartesian coordinate system) must be the same as the corresponding face(s) in the Simulation model." I have 0% match nodes. How can I change it to use this load in simiulation.
I simulate aortic valve leaflet simulation. First I did the CFX model, calculate the flow and as a result from CFX I need to apply the pressure from CFX to the structure in WB. in CFX I defined the cfx surface as a boundary and I would like to use it in WB But the are diferences in the CFX computed pressure and the mapped pressure. PLease if fou could suggest anything I will be apriopriate.
best regards.
Chris
nasdak is offline   Reply With Quote
Old   April 14, 2010, 14:22
chris
More information
I have started the calculations and I get the comment from output like this:
The calculated reference FORCE CONVERGENCE VALUE = 9.889812075E-03 is less than 1E-2 a threshold zero, A value of 1E-2 or specified MINREF
is used. Check results carefully.
In monitor I got the displacement values much less than I expected.
If you have any ideas what is wrong please help.
Best regards Chris
stagnation pressure boundary problem mbgnfrx2 STAR-CD 2 November 26, 2012 00:55
2D simulations in CFX - PROBLEM CFX user CFX 2 March 10, 2009 17:53
Pressure correction problem richard_larson OpenFOAM Running, Solving & CFD 8 October 30, 2008 09:48
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
