April 12, 2010, 08:21 |
domains for fan
Domenico
Rep Power: 17 |
Dear all,
I was simulating a fan and 3 components have been included. these components from the inlet to the outlet of the fan compressor are (see the attached file): - inlet part which is identified as rotor and includes the initial part of the nose from r=0; - rotor part where is possible to identify the rotor blades of the fan; - stator where is possible to look the stator blades. However I'm not sure that this case can work because for only one stage we are using 3 domain instead of two (rotor and stator only). Somebody knows if my solution is fine or not? Kind regards Domenico |
April 12, 2010, 18:33 |
Rep Power: 144 |
It should work fine. Why do you suspect it does not work?
April 14, 2010, 07:19 |
Attesz
Rep Power: 17 |
why is your inlet part defined as rotor? isn't it a slice of the inlet pipe? it's not wrong using 3domains instead of two.
April 14, 2010, 08:29 |
Domenico
Rep Power: 17 |
The reason why you have the first part as a rotor part is because in that domain at the hub level you have the part of the nose which has to achieve the radius 0. the nose has to have the same rotational speed as the rotor, for mechanical continuity reasons.
Kind regards Domenico di Cugno |
April 14, 2010, 18:28 |
Rep Power: 144 |
You use rotating frames of reference when the mesh needs to rotate. If the geometry is axially symmetry then you can either choose it to be a rotating frame of reference or a stationary frame of reference. If the wall in the axially symmetric body is not in the frame of reference you can then choose it to be a rotating wall (for a stationary frame of reference) or a counter rotating wall (for a rotating frame of reference).
I think that was a complicated explanation of a simple concept. Hopefully you get the idea. You should try to minimise the number of GGIs. With the trick mentioned above you should eb able to eliminate one of your GGIs. But I repeat my comment from my first post. What makes you think what you are doing is wrong? If you use 2 or 3 domains it should still give the same result. |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
No Heat Transfer between two solid domains | Mike ZH | CFX | 7 | July 26, 2008 16:50 |
buoyancy in two separate domains | DenizeN | FLUENT | 0 | January 16, 2008 15:33 |
Multiple domains - buoy. ref. temp. setting | Forrest | CFX | 8 | February 22, 2006 13:43 |
Multiple domains | Andrew | CFX | 5 | March 1, 2005 14:25 |
