Solid Fuel Modelling
Old   April 7, 2010, 10:23
Post Solid Fuel Modelling
T.J.Taha
Jeberti is on a distinguished road
I am working on solid fuel combustion( both in biomass and coal). i was encountering problem in defining the mixture property of the solid HC fuels. In the manual of Ansys_CFX,for the volatile fuel material option, it gives the user an option to change among pure substance, fixed composition mixture and variable composition mixture.
once i define the fixed composition mixture with some mass fraction the
simulation stops with error message telling " only pure substance can be
put as volatile fuel material". i would like to know how to solve this
problem.
thanks in advance,
Jeberti is offline   Reply With Quote
Old   July 20, 2010, 13:03
Neil Duffy
neilduffy1024 is on a distinguished road
Hi, I'm only at a similar stage myself but have you checked that all the volatiles defined in your fixed composition mixture, i.e. CO, CH4, C2H2 etc, have actually been defined individually as pure substances in your model, along with the corresponding reactions?
Neil
neilduffy1024 is offline   Reply With Quote
Old   July 20, 2010, 17:29
T.J.Taha
Hi Neil,
Thanks for replying to my long time request!!!
the thing is i have got a solution to my problem. its not possible to define variable composition mixture or fixed compostion mixture in the HC fuel set up. As a result you can do it in the following step;
1- in HC fuel material set the fuel gas as a a compound CxHyOz( you can also add up S, Cl and N, depending on your problem)
2- set the molecular wieght of the volatile to be automatically calculated,( CFX assumes the compund to be a mixture of CH4, CO and H2,check the manual)
3- go in to your devolatalization reaction and set the devolatalization reaction out put to CH4, Co and H2. butu dont forget to balance the toatal amount of energy should be balanced ( E of CxHyOz = E of Ch4+ E of Co + E of H2). if the energy is balanced you can also balance the mass coeffiecents as well.
finally instead using CxHyOz in the devolatalization output you can use the mixture of volatile outputs.
I hope this will helpfull to advance in your work, if not i will have also another method to propose to you which depends on objective of your work
Enjoy working with CFD
Taha
Old   July 21, 2010, 18:43
Default Solid fuel model and user routine for reaction rate
Neil Duffy
Hi Taha,
Thanks for the info. The HC Fuel analysis seems to be quite limited alright. I am looking at biomass in particular and was hoping to include a range of additional species (in addition to CO, H2 and CH4) such as C2H2, C3H3 etc, so the HC Fuel model does not seem to be suitable for this. I would be interested in the other method you used.
On a slightly different topic, I am trying to set up sub routines to describe reaction/conversion rates for devolatilisation and char oxidation. For the char oxidation case I am currently trying to link a fortran routine (to describe the reaction rate - hopefully conversion rate later) to a multiphase reaction in CFX-Pre. However, despite following the manual it will not let me select "particle user routine", the only options available are mass arrhenius, gibb and field. This was even the case when I tried to load the example ccl given. If anyone knows why this is the case, it would be very helpful.
All the best,
Neil
solid fuel burning lizihujx Phoenics 3 September 20, 2012 05:26
burning of solid fuel lizihujx FLUENT 8 September 19, 2012 09:50
energy from solid fuel combustion Silvia FLUENT 1 August 3, 2005 14:23
Fuel Modelling in Diesel Engines, what's truth Jo Siemens 0 August 18, 2004 14:47
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
