wall condition for extended outlet
Old   April 6, 2010, 11:52
Default wall condition for extended outlet
kuhbuh is on a distinguished road
Hi everyone!
In my calculation, I extended the outlet to prevent inflow as recommend in the CFX documentation. I just want to ask if it's appropriate to assign the wall of the additional region as free slip (no slip in the main domain) so as not to further retard the flow. Is this correct? thanks a lot guys!
kuh
kuhbuh is offline   Reply With Quote
Old   April 6, 2010, 13:55
Dmitry Volkind
dvolkind is on a distinguished road
Depends on what You are modelling. Why don't You want to retard the flow?
dvolkind is offline   Reply With Quote
Old   April 6, 2010, 14:19
Hi! Thank you for your reply. I'm simulating 2 phase flow and there is some recirculation near the outlet. My outlet condition is based on experimental data and I'm afraid that further extending it would have some inaccuracy.
Old   April 6, 2010, 14:35
Dmitry Volkind
What are Your BCs?
Old   April 6, 2010, 14:37
My BCs are velocity in and pressure out. Tnx!
Old   April 6, 2010, 14:58
Dmitry Volkind
Then moving outlet further away most likely won't affect accuracy. With inlet speed specified You will get a higher inlet pressure then You would expect without moving the boundary. Thus, absolute pressure values might slightly change, but basically pressure differences are important. So, if the absolute pressure level does not have much effect for Your problem and extending the domain won't introduce new geometry features then I think it's OK to move the boundary.
By the way, wall shear stress at non-sleep wall is not the only cause of pressure loss, so there's no guarantee that You won't get any pressure drop in free-slip region.
Old   April 6, 2010, 15:02
Thank you very much for the input! I'll run few more simulations and check if there's effect. Thanks again!
Old   April 6, 2010, 19:41
The best way to look at it is you want to model what the experimentalists measured. If they had a long runner downstream of the test section, then model that. If they dumped it into a big tank then model that.
Old   April 8, 2010, 11:30
Thanks again Sir Glenn! I'll take note of that.
outlet wall, slip
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 10:28
Outlet boundary condition colen CFX 6 March 8, 2010 23:49
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 18:07
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
How can define our Outlet Condition? POR FLUENT 0 October 11, 2002 07:24
