Radial Load calculation
Old   March 31, 2010, 05:35
Default Radial Load calculation
NA
pump_passion is on a distinguished road
Dear All,
I am trying to calculate the radial load on a volute of a centrifugal pump using the function FORCE of CFX_Post.
I have obtained too high results for the forces:
Fx=5030N
Fy=7032N
Fz=negligible
My pumps makes an head of 177m, SG=1, D2=580m, b2=34mm (disks included), running speed=1740 rpm, NS=382
If I use the empirical formula (Lobanof & Ross) for the calculation of radial load, I obtain a total radial force of about 750N... which is far from the results calculated with CFX.
I need to calculate the pressure resultant on volute in radial direction (radial thrust). I think that the proble is the function FORCE of CFX doesn't consider only pressure forces.
Could anyone help me???
Thanks a lot.
Regards.
pump_passion is offline   Reply With Quote
Old   March 31, 2010, 08:02
The force function includes both pressure and wall shear forces.
The pressure force is worked out relative to the reference pressure. Have you taken that into account?
Old   March 31, 2010, 08:26
NA
No problem for the refence pressure, I have an axial symmetric surface. I made also some test changing the reference pressure and results doesn't change. What should I set to take in account only pressure forces and not shear stress forces.
Many thanks for your quick reply.
Regards
Old   March 31, 2010, 18:51
Then do a surface integral of pressure.
annular inlet, radial flow in exit max Siemens 0 November 19, 2006 14:46
Radial Force calculation sans CFX 0 July 5, 2006 10:07
Warning 097- AB Siemens 6 November 15, 2004 05:41
Using load vector for parallel partitioning Kevala FLUENT 0 May 1, 2001 13:11
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 09:19
