Is it possible to get value of a variable at given coordinates without a point?
Old   March 22, 2010, 17:58
Question Is it possible to get value of a variable at given coordinates without a point?
technocrat is on a distinguished road
Is it possible to get value of a variable at given coordinates without crating a point there?
Maybe it can be done via user fortran? How?
I want to implement my own boundary conditions (like d^2u/dx^2=0) that is why I need values of velocity like velocity and pressure at points with arbitrary coordinates inside domain.
technocrat is offline   Reply With Quote
Old   March 23, 2010, 06:37
You can create monitor points where ever you like. But keep in mind they just return the value of the element they are in, they do not interpolate between the nearby nodes.
But CFX has built in gradient functions for first order derivatives, not sure about second order derivatives. If available you should use those functions.
Old   March 23, 2010, 14:19
Dmitry Volkind
dvolkind is on a distinguished road
Greetings!
What kind of boundary condition is that? As far as I understand, d^2u/dx^2=0 yields a flat speed profile. Probably if you could estimate du/dx somehow, it might be easier to specify the velocity as a linear function of coordinate via expression. I also doubt that second order derivative can be used as a boundary condition for it's neither first-type nor second-type.
dvolkind is offline   Reply With Quote
Old   March 23, 2010, 16:20
Thank you for your answers.
Originally Posted by ghorrocks View Post
... You can create monitor points where ever you like...
Monitor points can not be used as locations in expressions (to set up my BC in CFX-Pre I need an expression that will give u values). It is possible to use Source points as locations, but I'll have to create hundreds of them (one per each hexahedra in two layers, closest to boundary) to approximate 2-nd derivative. This is possible (with perl script), but creating so much points is too slow according to my experience.
...But CFX has built in gradient functions for first order derivatives...
I didn't find a way to use this in CFX-Pre. For example this expression
probe(Velocity u.Gradient)@Source Point 1
produces error
The function 'probe' referenced in parameter 'Expression Value' in object '/FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT:Monitor
 Point 1' has an invalid argument, 'Velocity u.Gradient'. The solver does not support operator-suffixed variables here.
Old   March 23, 2010, 16:42
I think it doesn't. Normal vector to outlet boundary plane in my case is \{1,0,0\}. \frac{\partial^2}{\partial x^2}u=0 does'nt imply any relation between u values at different y coordinates (if you meant that). This condition just makes speed change smoother near outlet.
Old   March 23, 2010, 18:05
Maybe I can get what I want via user fortran?
I'm now trying to find appropriate data acquisition routin in manual, but hasn't succeed yet. Probably I'm looking at what I need and don't see it?
The locale is always the locale for which the User CEL routine is called. It is not possible to call USER_GETVAR for non-local information (for example, using the face gradients on BOUNDARY:Inlet for the boundary condition specification of a variable on BOUNDARY:Outlet).
cfx, user fortran
Point coordinates via orinial point address after decomposing diana OpenFOAM Running, Solving & CFD 0 August 6, 2008 11:27
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
How to edit point coordinates in ICEM? Alexey CFX 6 December 24, 2007 11:31
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
