multiphase simulation with NOT HOMOGENEOUS model |
March 15, 2010, 12:14 |
Ciro Cannavacciuolo
Rep Power: 17 |
Hi to everybody,
i'm trying to solve a big problem for me: planing hulls. Before doing this, I'm trying to simulate simple flowfields in order to set all the parameters: a 2D wedge semi submerged. In order to avoid to set parameters in wrong way, is someone able to give me some "first" suggestion? Thank you very much |
March 15, 2010, 15:10 |
Rep Power: 144 |
Make sure you try the free surface sharpening options. The default is not necessarily the best.
March 15, 2010, 17:33 |
Ciro Cannavacciuolo
Rep Power: 17 |
Thank you Ghorrocks for your reply.
I know what you mean. I have prepared a lot of multiphase simulations using Homogeneous model. Now I'm trying to use a Not homogeneous one because I think that it is the best for planing hull. I know that defalut options are not the best. I'm looking for someone that has experience wiht this kind of models that is able to gives me some specific suggestion. Again, thank you for your reply. |
March 15, 2010, 17:43 |
Rep Power: 144 |
I think you can still use the free surface model in a non-homogenous model. Not sure on that.
Your simulation is quite specialised so you will need to do your own optimisation of parameters. You will be very lucky if anybody else has any experience directly relevant to what you are doing, and even luckier if they are actually correct in the advice they give. |
March 16, 2010, 06:19 |
Ciro Cannavacciuolo
Rep Power: 17 |
probably you are right!
Now I'm working on some different setup...I'll update you about my progresses. Again thank you |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Multiphase Simulation | dungsidietquy | FLUENT | 4 | November 4, 2009 14:46 |
multiphase model and drag law | Yasmail AKARIOUH | FLUENT | 0 | April 29, 2008 08:44 |
Yplus for Multiphase Simulation | Mitch | CFX | 0 | October 31, 2007 05:10 |
Turbolence model for multiphase flows | lu | CFX | 1 | February 7, 2007 17:40 |
