March 15, 2010, 05:54 |
Implementing a breakup model into CFX
Rep Power: 17 |
Hello, i am sorry that i am contacting u directly hope you don't mind.
I am trying to make numerical investigation of droplets breakup in stratified flows. My geometrie is rectangular duct with horizontal part elbow and sloped part. That means i have two continuous phases at the beginning and then i should model this droplets, how can i do it thanks a lot |
March 15, 2010, 06:34 |
Rep Power: 144 |
You are proposing quite an advanced and difficult simulation. Have you experience in multiphase modelling?
You have not described much about what you are trying to do. Are the droplets coming in the inlet or are they coming from elsewhere? Is it a spray breakup? Are droplets breaking up and/or coalescing? |
March 15, 2010, 06:44 |
Rep Power: 17 |
The Droplets gonna be stripped from the water waves (Hydraulic jump) under the assumption that the height of this waves after stripping (drag bigger than surface tension effect) stay unchanged.
March 15, 2010, 15:24 |
Rep Power: 144 |
To model stripping of water droplets from breaking waves is going to be a tough job. There is no in-built model to do this. You are either going to have to model it directly with a free surface approach (and the model size will be huge) or develop some sort of droplet generation model in a eularian context. This will have to be tuned against empirical data. Either way I hope you are a CFD expert otherwise you have no chance.
March 16, 2010, 04:27 |
Rep Power: 17 |
Thx,
Do you know some work dealing with this kind of droplet generation model, I know it will be tough to implement this, i have nevertheless the theory (stripping, capillary waves,...) to do this only the first step how to integrate this... |
March 16, 2010, 07:12 |
#6 | ||
Rep Power: 144 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 07:19 |
CAD model sliver faces - CFX Mesh - Parasolid? | Ianto | CFX | 3 | February 8, 2009 19:32 |
How to use the competing reaction model in CFX 11 | NewCoalman | CFX | 0 | May 5, 2008 04:15 |
cfx default values for coeffients of k-e model | Mike | CFX | 0 | July 25, 2006 10:50 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 09:50 |
