Hex versus Tet
Old   March 11, 2010, 17:26
Default Hex versus Tet
Jade M is on a distinguished road
I am running a CFX problem with laminar flow through a duct. The fluid flows through some fins in the middle of the duct.
When I mesh with tet, for the same number of nodes, the run times for the tet are significantly greater than those for the hex. It seems that it takes much longer for the tet mesh's solution to converge (a lot more iterations). Why? I am assuming that the matrix size is the same as it is proportional to the number of nodes, correct?
Also, for a hex mesh, the number of nodes and number of elements are about the same. For a tet mesh, the number of elements is much larger than the number of nodes. Why?
Thanks so much for some greatly needed explanations!
Jade M is offline   Reply With Quote
Old   March 12, 2010, 00:41
The node/element counts is explained in the documentation, in the section which describes the control volumes.
How big an effect hex vs tet makes is problem dependent. If you are doing a simple incompressible flow it won't make much difference. If you are doing complex stuff like free surfaces, shock waves, etc etc the improved mesh quality in a hex mesh can make a huge difference.
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? snailstb ANSYS Meshing & Geometry 3 March 15, 2010 21:26
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
poly, hex dom, hex, tet azmir Siemens 0 October 31, 2007 20:24
hex mesh vs. tet mesh (for FEM solvers) Sam Main CFD Forum 0 July 1, 2005 16:11
HEX vs. TET Selina Tracy Main CFD Forum 1 May 10, 2001 06:19
