March 10, 2010, 06:50 |
Axial Flow Compressor, Frozen Rotor
Junaid Ahmad Khan
Rep Power: 16 |
Hello.
I generate the mesh in Gambit of rotor37.and split them in two parts upper and lower portion i want the lower part to be rotating and upper to be stationary. So i open CFXPre select turbomechienary -> axialFlow comperassor-> add two new components one is R1 (Rotating) and other is S1(Stationary) in R1 i add the lower mesh and in S1 i add Upper mesh. In R1 i define ,Hub,Blade,Inlet,Outlet,Periodic 1,Periodic 2,in Casing i add The upper portion of the mesh that i want to make the interface and similarly in S1 i define ,Casing,Inlet,Outlet,Periodic 1,Periodic 2,in Hub i add The Lower portion of the mesh that i want to make the interface. Now that i have successfully developed the Interface & Wrote the solver file, now that .def does not run in solver plz give any solution for this problem. |
March 10, 2010, 07:03 |
Attesz
Rep Power: 17 |
You didn't wrote about your boundary conditions settings, and a lot of things. Send the error message in the out file, and more detailed description about your problem.
March 11, 2010, 02:09 |
Thanks
Junaid Ahmad Khan
Rep Power: 16 |
Thanks For Your Help Attesz But I solve the Problem.
axial flow around a cylinder -heat transfer model? | Ralf Schmidt | Main CFD Forum | 1 | March 21, 2006 09:54 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 06:44 |
CFD-FASTRAN for helicopter rotor flow. | Steve | Main CFD Forum | 0 | January 19, 2006 16:13 |
axial flow pump, inflow boundary | tma | CFX | 3 | September 26, 2002 16:28 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
