March 5, 2010, 12:47 |
How to force hp-mpi a certain IP
grand master
Rep Power: 16 |
Hello everbody
Sometimes my connection gets lost and hp-mpi sets the ip to 127.0.0.1 and looses remote lic server. Is there a possibility to force with the cfxsolve command to connect to an solid IP? i know the rule with mpirun -netaddr but i dont get it with CFXSOLVE. Anyone has the same problem and can help? Greetz, GrandM |
March 6, 2010, 05:47 |
Rep Power: 144 |
Easy - rather than referring to the machine by its machine name give it the IP address. It should work fine.
March 6, 2010, 06:53 |
grand master
Rep Power: 16 |
can you give me an example with 4 partitions?
like cfxsolve -def bla.def- startmethod "mpichloc....parallel" - part 4 -netaddresorsso?!? i tried many commands but all do not seem to work. I simply dont know where to the ip. And i dont know neither if i can put it somewhere in the cfx pre GUI. |
March 6, 2010, 07:09 |
Rep Power: 144 |
No, you will have to define the machines as IP addresses in the hosts.ccl file in <CFX ROOT>/config directory. (I think that's right, I am doing this from memory)
March 11, 2010, 11:17 |
grand master
Rep Power: 16 |
hello! I think you mean the hostinfo.ccl ?
SIMULATION CONTROL: EXECUTION CONTROL: PARALLEL HOST LIBRARY: HOST DEFINITION: ******** Remote Host Name = +++++++++ Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX Host Architecture String = winnt END # HOST DEFINITION ****** END # PARALLEL HOST LIBRARY END # EXECUTION CONTROL END # SIMULATION CONTROL when i change host definition or remote host name to an ip instead of hostname its still not using the defined ip. or do i have to change it somewhere else? the mpirun option is -netaddr , so maybe i can add this line somewhere in the cfxsolve routine? this cannot be so hard, to point the hp-mpi to a certain ip, can it? greetz |
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 08:07 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 11:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 12:12 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 11:25 |
pressure force and viscous force | CFD | FLUENT | 0 | March 7, 2006 02:03 |
