March 3, 2010, 05:11 |
Udf
elsa
Rep Power: 16 |
how can I define a function (UDF) in cfx? I have a specific thermal function (Pennes equation) for a hemisphere.
March 3, 2010, 06:51 |
Rep Power: 144 |
I have no idea what Penne equation is. This link tells me it is a heat transfer model used in physiology - http://jap.physiology.org/cgi/content/full/85/1/35 - I assume this is what you are talking about.
Looks like you will be able to implement this using source terms on the temperature/heat equation. I don't think you will need fortran. CEL expressions should work fine and they are MUCH easier. |
March 3, 2010, 14:22 |
Cel
elsa
Rep Power: 16 |
thank you for your response.
yeah pennes is a bioheat equation. could you please tell me more about CEL or give me a clue that where I can read about it. thanks |
March 3, 2010, 17:58 |
Rep Power: 144 |
CFX documentation, reference manual - CEL Expression language.
March 3, 2010, 23:07 |
heat flux
elsa
Rep Power: 16 |
I have simulated a duct with constant walls temperature and air flow inside; how can I get the heat flux from one section of the duct to the other section? or is it possible to get the Nusselt number at one point in fully developed area?
March 4, 2010, 06:41 |
Rep Power: 144 |
Nusselt number - Yes, define a new variable with an expression with the equation for Nusselt number in CFD-Post. Then you can view it, make contours of it and anything else you can do with variables.
Do you mean the heat flux from the air to the wall (look at the wall heat flux variable) or do you mean the heat flux from the convection of the air (make a surface which intersects the flow and define a new variable of density*Cp*normal velocity or something like that.) |
March 4, 2010, 14:18 |
elsa
Rep Power: 16 |
Thank you
actually, I'm looking for hat flux to find the convection coefficient or Nusselt number. if I can define the Nusselt number, there will be no necessity to calculate the heat flux. the problem is I don't know how I can define the Nusselt number. |
March 4, 2010, 16:45 |
Rep Power: 144 |
As I said, in CFD-Post you need to define a new variable which is an equation to define Nusselt number. Then you can view it in CFD-Post. Have a look at the CFX tutorials, some of them will define variables in CFD-Post for post-processing.
March 11, 2010, 00:05 |
#9 |
elsa
Rep Power: 16 |
I already have written the Pennes equation by Fortran, how can I apply it in CFX?
March 12, 2010, 00:53 |
#10 |
Rep Power: 144 |
As I said, define a variable in CFD-Post and you can get it from there. If you are doing it in the solver then have a look in the CEL reference guide for the list of available variables - you will find wall heat transfer to be useful for you.
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
