Help! Running parallel mpich2
Old   March 2, 2010, 12:06
Default Help! Running parallel mpich2
jpcfd is on a distinguished road
Hi all,
Im trying to run a parallel job using a local network consisting in two quadcores linked with a normal swich. The net seems to be right (both computers see each other) and rsh runs normally ( i can do the tipical remote probe). i also intall in both machines the mpich2 service and register the same user in both computers. Also i´ve shut down the firewall to avoid problems.
The problem is that it works all well but when the solver shows solver in the output screen it gets stoped and exit with code 0 responding to a command from the master node:
"Command on host returned with code 0" is the message.
at first i obtain code 255 too but now i only get code 0.
Can any one help me? i have read the parallel documentation i dont know were is the fail.
Thanks in advance for reading this and hope someone could help me.
Javier.
jpcfd is offline   Reply With Quote
Old   March 2, 2010, 18:00
Step 1 is to determine whether the problem is your simulation, the parallel setup or distributed parallel setup.
Does the simulation run OK serial? Does it run OK local parallel?
Old   March 2, 2010, 18:34
Thanks Glenn,
The problem arise when i use distributed setup. The model runs in serial and also in local parallel. I have the problem whtn i try to run working with two separates machines linked by a swich. I did the following:
0 be sure that the net is working and both computers can work
1 turn off firewalls
1 install mpich2 services in both
2 activate the services with the same log and pass
3 run the simulation.
4. i obtain error code 0 when the solver start.
Im forgeting something?
I will be pleasure of any help.
Thanks.
Old   March 3, 2010, 06:52
What OS are you using? Do the other parallel options work (eg HP MPI, PVM)?
Old   March 4, 2010, 08:49
Im using XP64. I try with MPI and it doesnt work aswell.
Thanks.
Old   March 5, 2010, 08:31
SanS
sans is on a distinguished road
Hi, This wont solve your problem but just try switching your master node and slave. See if you get the same error.
sans is offline   Reply With Quote
Old   March 6, 2010, 10:48
martin
tvt_mvt is on a distinguished road
try to use a differnet partition mode, e.g. user defined direction
martin
Originally Posted by jpcfd View Post
Hi all,
Javier.
tvt_mvt is offline   Reply With Quote
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 09:53
Running dieselFoam in parallel. Palminchi OpenFOAM 0 February 17, 2010 05:00
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
