Turbulence Schmidt Number for AV
Old   February 26, 2010, 10:08
Default Turbulence Schmidt Number for AV
Scott Nordsen is on a distinguished road
What is the Turbulence Schmidt Number used for the diffusive term for additional variable transport equations? I expect it is 2 for k-w, but what if a k-eps is enabled where the Sc,t is different for the equations?
Background:
I am using additional variables (AVs) for a turbulence model.
As a test, I implement k-w model for a mixing layer.
For a first step, I am setting source terms based on CFX k and w.
Thus, the k and AV k equations should have the same source terms.
I expect that my AV k will be pretty close to CFX k. However, there are differences.
For this problem this can only be the diffusive term
Thanks
Scott Nordsen is offline   Reply With Quote
Old   February 26, 2010, 10:31
John is on a distinguished road
As I recall, the default Turbulence Schmidt Number for species transport equation is 0.9.
John is offline   Reply With Quote
Old   February 26, 2010, 12:10
Thanks that seems to have done it
Next question is how to change? What if no heat transfer option is set?
Old   February 26, 2010, 18:21
TURBULENT FLUX CLOSURE:
Option = Eddy Diffusivity
Turbulent Schmidt Number = ??
END
Old   March 12, 2010, 15:22
I was wondering if there are other options for Option = ...
I would like to have a different turbulent diffusivity for the scalar equations than the momentum equations.
I have tried doing this by having a fancier function for the kinematic viscosity setting at the Domain Level.
However, it seems to be more restrictive on the variables being passed than say at the Subdomain level for the source terms.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Turbulent Schmidt Number John FLUENT 8 June 1, 2015 06:04
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 03:17
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulent Schmidt Number in SST model ? David CFX 0 December 5, 2005 05:43
