"wall normal velocity" on moving surfaces (FSI)
Old   February 22, 2010, 05:13
Default "wall normal velocity" on moving surfaces (FSI)
Andreas
andey is on a distinguished road
Send a message via ICQ to andey
Dear all,
recently, I've discovered some problems calculating the energy transport rate of a moving boundary wall in an FSI-analysis (ANSYS/CFX). The equation I've tried to use is
dE/dt = int_S( v ( -p + 2 mu )( -n) dS
with
v: boundary velocity
p: pressure
mu: shear force
n: normal vector
S: moving surface
My problem is the normal velocity of the surface, which should be calculatable by
normalvelo = areaInt(Wall Normal Velocity)@FSIN
Although I do not get any error messages during preprocessing nor solution, I get an "ERROR. The following unrecognised name was referenced: Wall Normal Velocity" in postprocessing.
The help files are not too helpful this time. Has anybody have a hint for me? Or even a suggestion how I could obtain these values from the structural (ANSYS) side?
Thanks a lot in advance,
best regards,
Andreas
andey is offline   Reply With Quote
Old   February 22, 2010, 09:54
stumpy is on a distinguished road
First, I hope you mean areaAve rather than areaInt.
Try creating a monitor point for your expression. If that works, then it just means that variable is not written to the res file by default, hence is not available for post-processing. Under output control you can select extra variables to write to the res file.
stumpy is offline   Reply With Quote
Old   February 22, 2010, 10:13
Andreas
Hi Stumpy,
thanks a lot for the fast reply! Do you think that "areaAve" is correct? Since finally I need an integrated value over the surface.
I already put the variables in the Output Control ("Wall Normal Velocity", "Wall Normal Velocity X", "Wall Normal Velocity Y", and "Wall Normal Velocity Z"). Nevertheless for some reason they cannot be taken for post processing.
I've also tried to set a Monitor Point for the WNV but - according to the help files and my try outs - WNV is not available for monitoring. Nevertheless, the help files say that post processing would be a available.
Do you maybe have another idea?
Thanks again and best regards,
Andreas
Old   February 22, 2010, 14:16
Try using "Mesh Velocity" instead.
Sorry, I didn't read the equation when suggesting areaAve. It just seemed like areaInt(velocity) was a strange thing to calculate. Still, is the wall velocity the same everywhere? In other words can you move v outside of the integral in your equation? If not, then I think you need to compute v ( -p + 2 mu )( -n) before performing the integral, so you'd need an Additional Variable equal to this part.
Old   February 23, 2010, 06:16
Andreas
Hi Stumpy,
thanks for the hint. "Mesh Velocity" should work, but in this case I loose the normal direction information. I actually do not have a too precise idea how i can calculate ( -p + 2 mu ) in normal direction. The way I now try to go is to write a little script in ADPL to get the normal wall velocity from the ANSYS side.
Best regards,
Andreas
Old   February 23, 2010, 22:24
There's a normal vector variable. I think it's Normal X, Normal Y and Normal Z. You could dot the Mesh Velocity vector with the Normal vector.
Old   February 24, 2010, 03:37
Andreas
Great! Thanks a lot!
cfx, fsi, wall normal velocity
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
moving wall- FSI skd FLUENT 0 May 8, 2006 10:21
Normal Vector on Curved Surfaces Karl FLUENT 0 July 2, 2001 05:35
