February 20, 2010, 22:58 |
finding flow angle
Help me in finding/claculating flow angle after analysis of centrifugal impeller.
February 21, 2010, 08:17 |
use vector and stream line in the cfx post.
July 29, 2010, 14:51 |
Diego
Rep Power: 16 |
in my case I have two vectors in a 3D domain, respectively Velocity in Stn Frame and Axial Velocity, of which I want to calculate the angle between themself. What is the best way to do this? There is a function to calculate the angle?? I think it is not possible to play with simple sin,cos... Help me. Thanks a lot. |
July 29, 2010, 19:57 |
Rep Power: 144 |
CEL has atn and atn2 functions. They can give you angles. Can do this is CFD-Post or in the solver with a monitor point.
June 3, 2015, 08:50 |
chiranjivi
Rep Power: 12 |
How can I use this function? Suppose I have to find the angle of attack over a cross flow turbine then what expression should be used
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
angle for wall adhesion in two phase flow | Al-jasim | FLUENT | 0 | August 18, 2007 11:04 |
Modelling flow over airfoil at near stall angle | Kelvin | FLUENT | 5 | June 6, 2007 03:00 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 09:42 |
Finding angle from line1 to line2 in ccw sense(2d) | zonexo | Main CFD Forum | 2 | September 9, 2005 07:40 |
