Velocity field problem
Old   February 24, 2010, 05:23
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
Originally Posted by zandi View Post
fine
would you please explain it more
I want to learn actually
you mean that your problem was about velocity in x and y direction?
there are 4 secondary flows in the plane normal to the main direction flow. directions of these flows are exactly as same as attached file but vice versa.
these secondary flows make max velocity occur at appx. .7 y from bottom of the channel.(if they would be in correct direction)
feizaghaee is offline   Reply With Quote
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
Extract velocity field in certain time step to MATLAB spatialtime CFX 3 September 9, 2009 19:30
Convergence problem with thermal phase change model under low velocity conditions pitisrisuk CFX 0 July 21, 2009 12:21
Streamline superimposed on velocity field allamarein FLUENT 0 July 9, 2009 21:51
velocity problem phy FLUENT 1 February 8, 2008 18:12
