Some help with the results, please
Old   February 5, 2010, 16:53
Default Some help with the results, please
Zvonko Kostovski
zona is on a distinguished road
Send a message via Skype™ to zona
Hi, I've been working on a CFD simulation on a pumps for some time now, but I have some doubts about the results I'm getting from it.
This is my process of calculation
1. make 3D model is SolidWorks
2. create the mesh in ANSYS
3. make a simulation boundary conditions ShearStress, MassFlow in, Static Preasure outlet (I put hier 0bar is this OK or shoul I put normal preasure???), and I use frozen rotor
4.finally after the calculations I use turbo macro Liquid Pump Performance to calculate the head and efficiency, (I get strange result for the efficiency anny ideas why????)
5. I repeat the calculations for 5-6 different flows and get head and efficiency and make Q-H and Q-eta diagrams in EXCEL
is this a good way to works
is there an automated way to calculate more than one point at once and to get an automated Q-H diagram...
- what is better for pumps Shear Stress or K-epsilon (turbulence model)
what is reference radius and reference height in the Liquid Pump Performance calculation (I change them but nothing happends!)
zona is offline   Reply With Quote
Old   February 7, 2010, 17:25
Unless you know what the wall shear stress is then do not use it. Almost always you don't know the wall shear stress so let the turbulence model calculate it for you. Also consider the SST turbulence model over the k-e model. It is better in just about all respects.
Yes, you can automate your curve generation. Have a look in the workbench tutorials about how to get WB to do this.
As for if your method is good - the devil is in the detail. But if you have not done a mesh and convergence sensitivity study and checked your boundaries are appropriate and the physics models are good then you are just guessing.
ghorrocks is online now   Reply With Quote
Old   February 8, 2010, 04:01
Zvonko Kostovski
Hi thanks for the tips, can You, please be a little bit more specific about this
I was searchif the PDF files but with no luck
Old   June 6, 2013, 02:28
Default Hi I am facing the same problem
ccs_2v is on a distinguished road
Hi I am facing problems in getting Efficiency Values which make sense for a pump.
I am new to CFX ,Did you find any Solution, i have browsed thru the forum but cant make a clear direction, if the above was solved can you share the solution to get proper efficiency in CFX.
Thank for Help in advance.
ccs_2v is offline   Reply With Quote
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 09:02
validation of CFD results andy FLUENT 0 June 13, 2007 14:55
Problems with repeating results Lee Siemens 4 May 26, 2006 04:39
