convergence problem in a long pipe
Old   February 4, 2010, 18:04
Question convergence problem in a long pipe
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
hi freinds
i'm trying to simulate a long pipe (180 m length) with 1.5 m diameter that has a 90 degree curve in one third of length from begining.inlet boundry conditions are velocity of .8 m/s and static pressure. outlet boundry condition is velocity of .8 m/s normal to the boundry. after about 2000, residules don't change and they approximately became a smooth line parallel to each other. i use hexa mesh that each cell along the pipe has 1 meter length. i use multiphase option. does anyone know what can i do to obtain convergence.
feizaghaee is offline   Reply With Quote
Old   February 4, 2010, 18:57
ckleanth's Avatar
George
ckleanth is on a distinguished road
do you need to model the problem using cfd? you didnt say what you want to model anyway.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   February 4, 2010, 19:37
feizaghaee's Avatar
moein
i want to model the water and air flow.
Old   February 5, 2010, 11:49
feizaghaee's Avatar
moein
i work with CFX 11.0.
Old   February 5, 2010, 12:22
ckleanth's Avatar
George
I will reiterate; you did not say what you want to model, no information on the physical or how you modeled it. if you want an answer please post an apropriate question.
Top 4 tips
Old   February 7, 2010, 17:20
For general comments on convergence see here:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   February 8, 2010, 18:45
Ali Torbaty
AliTr is on a distinguished road
1m mesh length is large if you are modeling multiphase Air/water, you haven't told the other mesh dimensions but relatively they should be large as well. you need smaller mesh size for better resolved water surface, in most of the Air/Water models, this is the reason for flat line convergence.
you can also try smaller physical timescale while reducing the mesh size.
AliTr is offline   Reply With Quote
Old   February 16, 2010, 09:05
feizaghaee's Avatar
moein
i solved it by changing the time scale. tanks a lot everyone
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 08:05
Continuity eq convergence problem carno FLUENT 4 February 8, 2008 05:04
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
convergence problem Trushar Phoenics 5 August 28, 2002 00:40
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 21:26
