joining two domains using boundary conditions |
February 2, 2010, 08:54 |
Jake Mealy
Rep Power: 16 |
hi all,
is it possible to connect the outflow from one domain to the inflow of another domain in ansys? i have specified different fluids in each domain and i want one to flow into the other and mix. any ideas? cheers. |
February 2, 2010, 17:28 |
Rep Power: 144 |
You might be able to connect them using periodic boundary conditions.
February 4, 2010, 03:12 |
Guohua Gao
Rep Power: 16 |
I think you just need the Domain Interface instead of any boundary condition.
February 4, 2010, 06:00 |
Rep Power: 144 |
Good point - it depends on what you are trying to do. Can you describe what you are trying to do with this inlet/outlet more? Can you post a picture?
February 4, 2010, 12:09 |
Attesz
Rep Power: 17 |
February 10, 2010, 11:31 |
Jake Mealy
Rep Power: 16 |
Yeah, I was actually just making the problem more complicated than it needed to be. But a domain interface definitely works best I think.
Thanks for your help guys. |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
Problems with boundary conditions for a lowRekOmegaSST turbulence model | cfdmarkus | OpenFOAM Running, Solving & CFD | 16 | November 14, 2011 05:44 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 19:03 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
