September 4, 2011, 06:57 |
#21 |
Max
Rep Power: 15 |
Of course, you are right. But a deviation of lets say 2 seconds caused by taking the time manually at measured times between 2 and 3 minutes, only means an error of 1%.
So I guess this is not the reason for the poor performance improvement. Any other idea what the reason could be? |
September 4, 2011, 21:11 |
#22 |
Rep Power: 144 |
I do not trust your measurement yet. Please recalculate based on CFD Solver wall clock seconds reported immediately after the iterations are complete.
September 5, 2011, 08:39 |
#23 |
Max
Rep Power: 15 |
Serial: CFD Solver wall clock seconds: 2.2300E+02
HP MPI Local Parallel, 4 Processes: CFD Solver wall clock seconds: 1.2000E+02 (factor 1.86) HP MPI Local Parallel, 7 Processes: CFD Solver wall clock seconds: 1.1000E+02 (factor 2.03) This time, i used a different case with a smaller mesh (~ 600 000 elements). |
September 5, 2011, 19:47 |
#24 |
Rep Power: 144 |
I see. Forget about the 7 processes model, you are always going to get terrible speedups with hyperthreading. A speedup of 1.86 at 4 processes is not very good. You should be over 3 for modern processors. Have you run the benchmark simulation? That is the reference I use to benchmark solver speed.
But I think you can be pretty sure something is wrong with your setup and is robbing you of multi processor speed. |
September 8, 2011, 04:43 |
#25 |
Max
Rep Power: 15 |
First of all, thanks for your help!
Here are the results for the Benchmark run: Serial: CFD Solver wall clock seconds: 3.0000E+01 HP MPI Local Parallel, 4: CFD Solver wall clock seconds: 1.6000E+01 (--> factor 1.88) I checked the memory usage during my last runs and it was never fully used. Also, I tested another machine. It's a Core i-5 2500 (the one I usually use is a Core i-7 2600). The speedup factor on this machine was only 1.9, too. I dont know too much about CPUs, but maybe there is some kind of automatic down-clocking when several cores are used ... |
September 8, 2011, 08:51 |
#26 |
Rep Power: 144 |
If the benchmark problem runs at a similar speed then you definitely have a problem with your set up, it is not the simulation.
Recent Intel CPUs do run a higher clock speed when running single processor, this could explain it. To check this run it 1, 2, 3 and 4 processor. If the 1 processor result is clearly different then this probably explains it. The benchmark in 30s and 4 processes in 16s is very fast - must be quite a new machine. So I would recommend trying other multi processor implementations such as MPI, HPMPI, PVM, Intel etc. You may be able to get better speedups from them. |
June 25, 2012, 09:55 |
#27 |
OJ
Rep Power: 20 |
I have i7-2860QM (4 cores) and 8 GB RAM.
Popular opinion in this thread is that 4 cores give optimum performance. Question is, would keeping simulation on for hours harmful for life of system? I can feel the system heating up as I see the 4 processors loaded at ~100%. |
June 25, 2012, 10:01 |
#28 | |
OJ
Rep Power: 20 |
Popular opinion in this thread is that 4 cores give optimum performance. Question is, would keeping simulation on for hours harmful for life of system? I can feel the system heating up as I see the 4 processors loaded at ~100%. Quote:
Thanks OJ |
June 25, 2012, 20:01 |
#29 |
Rep Power: 144 |
When CPUs run hard they run hot. Well designed systems can handle the load and should still function fine. Poorly designed systems will overheat and cause problems - I think the i7 chips sense their own temeprature and if they are too hot they slow down to stop overheating. This saves the CPU but means you are running at reduced speed.
As for which multi processor implementation is best, the simple answer is to benchmark them all on your system. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
