Error after meshing/before defining conditions
Old   January 26, 2010, 06:13
Default Error after meshing/before defining conditions
Atella is on a distinguished road
Im using CFX through ANSYS workbench, I am fairly new to CFX so have been following the CFX tutorials available online.
I am trying to model the flow around a vehicle and so have applied the techniques used in Tutorial 5: Blunt Body and applying it to what i require.
After setting up my mesh in CFX mesh i try to open up the 'setup' section to define my loads etc but i get the following error:
ERROR Syntax error: %s parameters should have the format: load
ERROR
Syntax error: action 'wbloadmesh' parameters should have the format: param=value
Anyone know why this is and how to solve it?
Any help is much appreciated
Thanks
Atella is offline   Reply With Quote
Old   March 2, 2010, 14:17
Christopher Rose Petrilli
christopherrosep is on a distinguished road
Hi, i have the same problem with Ansys 12, do you have any idea ?
christopherrosep is offline   Reply With Quote
Old   March 2, 2010, 14:23
It turned out to be a problem with my working directory, after meshing the object i saved the whole workbench file as a new name, which it didnt like and gave that error.
I had to basically start again with a new working directory and saved as I went along using the same file name.
If this sounds like something you did then its worth trying to load the simulation from where you last didnt have any problems
Old   September 25, 2017, 18:28
Joey A
ja21 is on a distinguished road
I had the same error and it appears that having commas in the workbench file name caused the issue. I did a save as without commas and everything seems to be working fine.
ja21 is offline   Reply With Quote
cfx, error, meshing
Defining "Neutral" boundary conditions? (force=0) MW FLUENT 5 October 5, 2009 05:55
[Urgent] Need help for defining boundary conditions Jingwei FLUENT 2 March 19, 2009 22:01
Defining Boundary Conditions in GAMBIT Tim R FLUENT 3 April 14, 2008 05:30
Defining Boundary conditions in gambit anthro FLUENT 2 February 14, 2007 10:17
Defining Outlet conditions Luis CFX 0 April 4, 2005 21:36
