January 23, 2010, 20:09 |
How to set boundaries about airfoil in CFX
Yibin Dou
Rep Power: 16 |
hi, everyone. I am not familiar with CFX and these days i try to learn how to use CFX to calc the airfoil, wing and other more complicated configures. I have got a RAE2822 airfoil grids by ICEM and my problem is how to set the proper boundaries in CFX. From the literatures I have read, there are two different kinds of boundaries setting. First, set the farfield as OPENING, setting static pressure and velocity. Another is set VELOCITY INLET and PRESSURE OUTLET. Set velocity in INLET and average pressure in OUTLET. I am confused about which one is proper. The tutorial says OPENING boundary only can be used in subsonic. So if i want to simulate a transonic case, do I have to choose VELOCITY INLET and PRESSURE OUTLET? Thanks a lot.
January 24, 2010, 13:00 |
Yibin Dou
Rep Power: 16 |
I am looking forward to anyone who can help me! Thank you
January 24, 2010, 20:20 |
Rep Power: 144 |
For subsonic flows a velocity inlet and a outlet with a set pressure makes sense. For transonic/supersonic flows if it is possible to extend the outlet downstream so the flow is entirely supersonic that would help. Not sure how to deal with it if this is not possible, it is not my field of expertise. All I can suggest then is to read the documentation.
cfx boundary airfoil |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
hi how to set entironment variable in CFX pre | romance | CFX | 0 | December 23, 2007 08:11 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 20:51 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
