January 12, 2010, 04:52 |
How to measure thrust ?
Attesz
Rep Power: 17 |
Hi all,
I'm simulating a quadrotor RC helicopters propeller: http://www.cfd-online.com/Forums/cfx...imulation.html The main goal is to find the best blade shape. To get this, I have to measure thrust in CFX post. Now, I define a plane behind the rotor, and let the CFX calculate the normal force on it. The CFD forces are smaller than measured. I know, it can caused by a lot of things, but maybe I'm wrong in force calculation. So my question is: how to measure the thrust of the propeller? Thanks, Attesz Last edited by Attesz; January 12, 2010 at 13:28. |
January 12, 2010, 17:04 |
Rep Power: 143 |
Most people are more interested in the thrust from the rotor, not a plate underneath the rotor. Why don't you calculate the thrust on the rotor blades?
January 13, 2010, 03:27 |
Attesz
Rep Power: 17 |
Hi Glenn,
I've calculated normal force on the rotor blades, but the values are lower than on the plane measured, so more lower than real. I don't know why? I think, CFX calculates the force on a plane from the equation massflow*velocity, which is the general equation for thrust calculation. To this equation comes the pressure difference member: area*(pressure@outlet-pressure@environment), which has a low value in my work. Thanks for your reply, Attesz |
January 13, 2010, 05:50 |
Rep Power: 143 |
So let me paraphrase you: When you put in a feature which has nothing to do with the rotors the force acting on it is closer to what you think it should be so therefore you will use this force rather than the force on the rotors which is actually what you want.
Pardon my sarcasm but I think this line of logic is not helpful. If the force you want seems wrong then you should look at the accuracy of your simulation rather than doing some fudge on the results to make it appear better than it is. Calculate the force on the rotor using the forceX/Y/Z() function, and if the answer is wrong then you have an error in your simulation and you should fix it. |
January 13, 2010, 06:17 |
Attesz
Rep Power: 17 |
Thank you Glenn,
but I didn't want to cheat, I didn't know how to measure force simply. I tought measuring that is more difficult, than measure it on the blades. However, I'll examine the mesh, but also the measuring of the real quadrotor can be inaccurate (ground effect, the effect of rotors to each other, and also the "measuring device": a kitchen balance . it's a student team project). Best regards, Attesz |
September 29, 2017, 23:20 |
arman
Rep Power: 10 |
Hi all
Im working on a propeller and i have to calculate thrust in cfx but i dont know from where I am start .can you help me? |
October 2, 2017, 05:35 |
urosgrivc
Rep Power: 11 |
You are probably looking at something like a rotating domain problem.
depends on your case, let say, if you have some other parts blocking the flow which could produce downforce and not lift than you need to include those surfaces too and measure force on these also. You can probably include simetry which will aid speed, resolution and convergence to your problem. -make a geometry of the surrounding air (you most probably do not need a propeler volume in your simulation just air that surrounds it). -make a nice mesh, finer near the propeler surfaces maybe some inflation layers. -rotate it -Force_direction@propeler surface , is your ansver for force generated by the propeler. |
March 23, 2018, 21:47 |
arman
Rep Power: 10 |
hello
thank you. You can also help me with the mesh.please? i think my mesh is not well.but my geometry is true. I must also say that I am studying the problem about surface piercing propeller. |
March 24, 2018, 05:04 |
#9 |
urosgrivc
Rep Power: 11 |
The mesh should be very fine near the wals if you have high velocity you vill find out that mesh quality and density will play a big role in geting the corect result. This case should be done in tranzient if both the rotor and the body of the quadrotor will be done in the same simulation but be prepeared for wery long computational time. Consider doing rotor simulation seperately from the body simulation
armanpournasiri this is probably your ansver. surface piercing propeller? you mean vater surface like half the rotor outside and half inside the water? this can be done by activating multiple fluids in a single domain and activating gravity maybe even additional surface tension model. I can only see this vorking in transient though. Last edited by urosgrivc; March 26, 2018 at 01:11. |
March 26, 2018, 22:25 |
#10 |
arman
Rep Power: 10 |
Hello and thanks for your help.
In the case of the mesh, I must say that my mesh aspec retio is 68.52 which is less than 100 .but my skwnes is .99 that i think it do not fit. also about On the topic that you guessed right. propeller works between water and air . my next question is :do i need to udf in my question? becuse i I do not know programming. |
March 26, 2018, 22:30 |
#11 |
Rep Power: 143 |
Mesh quality requirements vary simulation to simulation. Some simulations require very strict mesh quality, some are much looser. The numbers in the output file are just guidelines.
Please show an image of what you are modelling and how you propose to model it.
March 27, 2018, 04:16 |
#12 |
urosgrivc
Rep Power: 11 |
I can imagine only few basic expresions being used in the surface piercing propeller simulation.
maybe for initial conditions of water location, and for force or moment monitors. But I think this kind of simulation is only posible to do in transient and it will probably include rotating and stationary domain. explain more |
measure, quadrotor, thrust |
Thrust calculation | Tony | CFX | 4 | July 9, 2012 11:48 |
Thrust value, positive or negative? | Emmanuel | FLUENT | 0 | June 25, 2007 19:47 |
3D Ejector Thrust Calculation | Emmanuel | FLUENT | 0 | April 6, 2007 13:59 |
pressure measure in centrifugal pump vanes | Patricio Torrejon | FLUENT | 1 | December 16, 2005 17:10 |
Add Measure Markings or Coordinates to the Contour | Colin | FLUENT | 4 | August 25, 2004 09:54 |
