Is it possible to influence the velocity of an scalar transport equation?
Old   January 9, 2010, 19:05
Default Is it possible to influence the velocity of an scalar transport equation?
jannnesss is on a distinguished road
Hey everyone!!
Is there any possibility to influence the velocity of an scalar transport equation. I want to reach the scalar is transportet by another velocity than the flow velocity.
For example: the transported scalar should move with a fix (very small) velocity in the radial direction of a pipe, when the main flow is in the direction of the pipe.
Thanks a lot!
With best regards, Jan
jannnesss is offline   Reply With Quote
Old   January 11, 2010, 13:02
Tristan Burton
Tristan is on a distinguished road
Jan,
What's the physical mechanism here? Can you get the radial advection with a modification to the diffusion coefficient? If you don't want advection due to the flow velocity, it seems like you should use a diffusive transport equation and adjust the diffusion coefficient to get the desired behavior. I know that in turbulent particle-laden flow modelling they talk about particle "diffusion" even though particles don't really diffuse, but their response to the turbulent velocity fluctuations can be treated as a "diffusion".
Tristan
Tristan is offline   Reply With Quote
Scalar transport equation dimension problem litonx OpenFOAM Running, Solving & CFD 3 March 2, 2007 07:49
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
transport equation for SGS scalar variance chinthakindi Main CFD Forum 0 April 27, 2004 10:26
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Scalar Transport Equations 123 Main CFD Forum 6 August 10, 1998 10:05
