January 6, 2010, 17:39 |
CFX mesh inflantation problem
Hi, I'm working on a pump flow analysis
I got some strange results so now I'm refining the mesh, any advice about the mesh elements sizes I think (I don't know if I'm right, that smaller inflantation is better but if I put inflantation 0.001 with the volume mesh I get warning big aspect ratio (default body spacing 0.005, default face spacing min 0.001 max 0.005) only if I put inflantation 0.005 I don't get the warning, but the inflantated region is quite big (or it seams to me it is ) . any advice on this subject, is there a big influence in the results depending on the inflantation (its a simple pump inlet - impeller - volute), by the way I/m using frosen rotor is this ok for calculations (I need q-h, q-power, and q - efficiency curves) |
January 8, 2010, 12:17 |
annyone ????
January 8, 2010, 23:17 |
#3 | |
Wish it help. Last edited by rikio; January 8, 2010 at 23:23. Reason: Addition |
January 9, 2010, 02:02 |
SanS
Rep Power: 17 |
Hi Your second mesh looks good, only problem is the big transition from the prism to the tets. Generally you would have convergence problems. I would increase the number of layers and the prism expansion ratio to get a better transition.
Frozen rotor does give good results for pumps but your final results does depend a lot on other factors also. |
Mesh Adaption in CFX. | Kushagra Mittal | CFX | 1 | August 31, 2011 09:17 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
CFX mesh cause software blocked | ahlo | CFX | 3 | December 13, 2007 14:34 |
CFX mesh & ICEM | mike | CFX | 3 | April 27, 2006 16:27 |
ICEM CFD 5.0 - CFX mesh problem | NeedHelp | CFX | 2 | January 4, 2005 14:45 |
