desperate Fatal overflow in linear solver - transient
Old   January 4, 2010, 08:13
Default desperate Fatal overflow in linear solver - transient
kingjewel1 is on a distinguished road
Hi there,
I'm a bit desperate here, tried everything i can think of
I'm running a simulation of a ventilated room (with k-e) under transient conditions and the solver has a fatal error after the first iteration. Steady state runs nicely even under high resolution scheme. Any Ideas? please
| K-TurbKE | 2.00 | 4.1E-02 | 8.9E-01 | 6.3 2.2E-02 OK|
| E-Diss.K | 2.26 | 5.4E-02 | 1.9E+00 | 7.1 3.8E-04 OK|
COEFFICIENT LOOP ITERATION = 2 CPU SECONDS = 1.244E+02
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 0.00 | 1.3E-13 | 1.8E-12 | 3.2E+10 * |
| V-Mom | 0.00 | 1.3E-13 | 2.9E-12 | 3.1E+10 * |
| W-Mom | 0.00 | 4.1E-13 | 3.0E-12 | 9.6E+09 F |
| P-Mass | 0.00 | 0.0E+00 | 2.9E-24 | 9.7 9.1E+10 * |
| Contaminant | 3.85 | 7.4E-03 | 2.2E+00 | 6.0 3.2E-02 OK|
| ERROR #004100018 has occurred in subroutine FINMES. |
| Message: |
| Fatal overflow in linear solver. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver has terminated without writing a results |
| file. Command on host phipc (PHI-PC) exited with return code 0. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory C:\Users\Phi\Documents\New |
| folder\Single\Standrews8_transient_013: |
| 777_full.trn |
kingjewel1 is offline   Reply With Quote
Old   January 4, 2010, 08:30
shogologo is on a distinguished road
Which Timestep did you chose?
shogologo is offline   Reply With Quote
Old   January 4, 2010, 08:32
Timestep is 10s for total of 30mins. Also gives the same problem with adaptive timestepping and regardless of initial value file.
I'm worried about the simulation always giving RMS Courrant Number=0.00 and then jumping suddenly 999 after first iteration then crashing.
Old   January 4, 2010, 09:26
I managed a similar type of simulation.
My suggestion is to reduce timestep so to get Courant between 2 and 10 (or at least 30).
So I would try reduce to 1e-2 / 1e-3 sec...
Old   January 4, 2010, 12:45
Thank you. Its running with a Courant number at 21 with a 0.1 second timestep. Why does it require such a small timestep for this type of simulation? I don't need this much precise detail, as the code will take, I calculate, 60 days to run 30 mins of simulation.
What was your simulation?
Old   January 5, 2010, 05:51
You can try to speed up the timestep "on the fly" to understand which is the characteristic timescale.
It should depend mainly by grid size and Reynolds number.
Old   January 5, 2010, 08:17
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
why are you doing the simulation so long (i'm just interested)? Doing a steady simulation first, and after that a transient for 5min for example, will not be better? (just an idea, i don't know your goals).
Regards,
Attesz
Attesz is offline   Reply With Quote
Old   January 5, 2010, 12:17
I'm looking at the movement of particles/pathogens in a hospital room. The idea is to investigate different scenarios including, coughing, sneezing, bed making etc. In the end I'd also want to look at the way displacement ventilation suspends certain particles too. What do you think?
How do you change the timestep on the fly without going back into pre?
Old   January 5, 2010, 12:31
Attesz's Avatar
Attesz
I'm not experienced in transient simulation, but perhaps the value of timesteps can be adjusted by clicking on the "Edit run in progress..." button (I've never tryed it). In my centrifugal compressor simulation I've used adaptive timestep, to reach always the desired Courrant number (it was very important at me), and the timestep will be set "automatically" by the solver.
However, your simulation is very interesting!
Good luck,
Attesz
Old   January 5, 2010, 14:53
Thanks! I've just tried it and it works great.
Fatal Overflow when using RNG k-e Pascal CFX 2 February 5, 2008 17:41
free C code for large sparse matrix linear solver ztdep Main CFD Forum 7 May 24, 2007 15:14
Linear Iterative Solver + Elliptic PDE cfd101 Main CFD Forum 0 November 14, 2005 19:59
linear solver overflow peggy CFX 1 February 8, 2001 02:39
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 05:22
