francis turbin difference between experiment values and CFD |
December 23, 2009, 23:02 |
snoopy
Rep Power: 17 |
Hello.
I have something to solve urgently. Please please help me. I have flow rate 1.37 m^3/s at outlet from an experiment. I imposed initial conditions as 4.16ATM pressure at inlet but after CFX 11 runned I got a result 2 m^3/s at outlet. As I told you, I have to have result as 1.37 m^3/s at outlet. What should I do? I already checked modeling, scale and fluid properties and so on. Thank you in advance. Have a nice day. |
December 25, 2009, 03:20 |
Rep Power: 17 |
It may be that you have a problem with boundary conditions, you should take a look on this section from the CFX Help: ANSYS CFX Reference Guide | ANSYS CFX Best Practices Guide for Turbomachinery | Liquid Pumps and Turbines | and if the problem persists you should give us more details about the boundary conditions. |
December 28, 2009, 00:21 |
Hi Ali
snoopy
Rep Power: 17 |
Hi Mr. Ali. Thank you for your kind response.
I read turbomachinery boundary condition and set boundary conditions as it is said. I set inlet BC as 547.76 ATM of total pressure and outlet BC as 1370 kg/s of flow rate. But I can't find any difference between pressure of inlet and outlet. How can I fix it? Thank you in advance. |
December 28, 2009, 00:43 |
SanS
Rep Power: 17 |
Hi, Simple question, has your simulation fully converged? because there is no point in discussing results of an unconverged simulation.
Also where is this mass flow being measured? Is it at the outlet of the domain? |
December 28, 2009, 01:38 |
Re
snoopy
Rep Power: 17 |
Hi. My result are fully converged.
And I got results of inlet condition and outlet conditon from the experiment. I measured mass flow rate at outlet. Do you have any idea? |
December 28, 2009, 02:07 |
SanS
Rep Power: 17 |
Can you post an .out file here?
December 28, 2009, 02:14 |
hi
snoopy
Rep Power: 17 |
Hi
Do you know how to send file to you here? or please give me your e-mail address? |
December 28, 2009, 03:05 |
hi
snoopy
Rep Power: 17 |
Hi
I attached out file. please read it and give me a great idea. have a nice day |
December 28, 2009, 03:12 |
#9 |
Rep Power: 17 |
Hello all, Go to the bottom of the Reply to Thread page, in the Additional Options you can find Attach Files .The used BC at inlet is unrealistic, a total pressure of 547.76 ATM is very high and you can't find a correct solution. It's a good idea to attach your output file here. |
hi
#10 |
snoopy
Rep Power: 17 |
Hi
I attached out file. please read it and give me a great idea. have a nice day PS : inlet condition is 45m of head at inlet. and according to my calculation, the total pressure is 4.5 ATM + 0.5 * density * velocity^2 is 547.76 ATM am I wrong? |
December 28, 2009, 03:58 |
#11 |
Rep Power: 17 |
After reading your output file, I find this tow mistacs: 1- MASS AND MOMENTUM: Option = Total Pressure Relative Pressure = 547.76 [atm] END As I sad previously the total pressure is not correct????!!!!! 2- BOUNDARY: SH02 Boundary Type = WALL Frame Type = Rotating Location = SHROUD1 2 BOUNDARY CONDITIONS: WALL INFLUENCE ON FLOW: Option = No Slip END END END This Boundary is defined as rotating Boundary, but in reality it isn't. To define it as stationary, go to the Boundary Details and activate Wall Velocity then select Counter Rotating Wall in the option Box. You have to do that for all stationary boundaries in the rotating domain. |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
validation of CFD and windtunnel experiment | M.Arun prasad | FLUENT | 4 | March 13, 2008 03:12 |
CFD VALUES AT EXPERIMENTAL POINT | J | FLUENT | 1 | September 25, 2005 17:55 |
