Simulating roof heating in sun
Old   December 20, 2009, 06:07
Default Simulating roof heating in sun
Arakis is on a distinguished road
Hello everyone,
I am trying to use ANSYS CFX to simulate the heat transfer on a hot day from the roof of a house into the living areas. I ma having some difficulties setting up the simulation. In essence this is what I am trying to do:
There is the sun generating a heat flux onto the metal roof sheets.
The roof sheets get hot, which causes the air under the roof to get hot. This hot air then causes heat transfer through the ceiling into the living area. I am interested in the flow patterns and temperature distribution of the hot air that flows in the roof cavity, and would like to study the difference in the temperature in the roof cavity if there were openings in the roof compared to a sealed roof.
Any guidance or recommendations would help alot. Thanks
Arakis is offline   Reply With Quote
Old   December 20, 2009, 12:04
Abou ali is on a distinguished road
I think that Tutorial 17 in CFX help (Air Conditioning Simulation) treats a similar problem as yours, you can use it as a guideline in your simulation.
In general, you have to:
1- activate the Buoyancy Option in the Domain Models definition under General Options;
2- activate the Thermal Radiation Model Option in the Domain Models definition under Fluid Models;
3- use a Radiation sources in appropriate walls.
Abou ali is offline   Reply With Quote
Old   December 20, 2009, 13:38
Smile
Jack
rogbrito is an unknown quantity at this point
Tutorial 17 in CFX help (Air Conditioning Simulation):
http://www.4shared.com/file/72198900...ningSimul.html
http://www.4shared.com/file/72199871...ningSimul.html
Originally Posted by Arakis View Post
Hello everyone,
rogbrito is offline   Reply With Quote
Old   December 29, 2009, 19:24
kingjewel1 is on a distinguished road
Dynamic Thermal Modelling is the study of the influence of the sun on indoor thermal comfort during the day. I don't know if CFX has a radiation model which allows for a moving heat source, unless you can model your heat source algebraically.
kingjewel1 is offline   Reply With Quote
Induction heating of hollow cylinder cfd.geek FLUENT 1 August 12, 2022 17:38
Pressure variation in a heating channel gRomK13 Main CFD Forum 0 August 6, 2009 13:18
Lower heating value Andrea Siemens 2 July 30, 2007 08:19
heat transfer - heating element to air in FloWorks Duncan Gravill Main CFD Forum 1 March 28, 2007 21:16
solar heat flux through roof Tim FLUENT 1 January 17, 2007 17:01
