December 15, 2009, 19:35 |
Reynolds Number- CFX Solver
Juan Lorenzo
Rep Power: 17 |
As the CFX calculates I number of Reynolds? formulates it uses it conventional? according to I have understood calculates the RE node-node but the values of a calculated value theoretically and the one that is observed in solver to manager are very different 1e5 theoretical ---- 7,3e5 CFX to solver?
I must work with the theory or adjust to which leaves in solver? |
December 15, 2009, 23:30 |
Rep Power: 144 |
The Re number reported in the solver is based on a length scale defined as the cube root of the total solution volume, and averaged velocities and material properties. This is not a useful definition of Re for comparison to literature so you must define a Re based on the length, velocity and material properties you define.
December 16, 2009, 10:07 |
Juan Lorenzo
Rep Power: 17 |
thanks Glenn...
December 19, 2009, 04:52 |
JiangBiao
it doesn't work
December 20, 2009, 17:28 |
#5 | |
Jack
Rep Power: 16 |
http://www.4shared.com/file/12861259...ldsNumber.html
January 23, 2010, 20:07 |
How to set the boundary of airfoil
Yibin Dou
Rep Power: 17 |
hi, everyone. I am not familiar with CFX and these days i try to learn how to use CFX to calc the airfoil, wing and other more complicated configures. I have got a RAE2822 airfoil grids by ICEM and my problem is how to set the proper boundaries in CFX. From the literatures I have read, there are two different kinds of boundaries setting. First, set the farfield as OPENING, setting static pressure and velocity. Another is set VELOCITY INLET and PRESSURE OUTLET. Set velocity in INLET and average pressure in OUTLET. I am confused about which one is proper. The tutorial says OPENING boundary only can be used in subsonic. So if i want to simulate a transonic case, do I have to choose VELOCITY INLET and PRESSURE OUTLET? Thanks a lot.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Reynolds Number matching in Cavity flow | Endee | Main CFD Forum | 6 | April 20, 2010 05:47 |
Reynolds Number Again | Ogbeni | CFX | 2 | June 3, 2005 00:34 |
Reynolds number in CFX | tuks | CFX | 0 | May 25, 2005 02:16 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
