December 4, 2009, 17:36 |
Error #001100279
Domenico
Rep Power: 17 |
Dear all I'm working on ANSYS CFX in order to solve the flow around a low pressure turbine. I'm a beginner of ANSYS CFX I don't understand the error that I have had after the running CFX some the ERROR #001100279, but I don't understand the reason.
Can somebody to explain to me what is happened? Thanks in advance Domenico |
December 5, 2009, 06:03 |
Rep Power: 144 |
Your simulation has diverged. Try starting with a smaller timestep or possibly a local timescale factor. Once it has started converging then you can wind the timestep up (or return to physical timescale if you used local timescale).
December 8, 2009, 22:07 |
Bharath kumar
Rep Power: 17 |
Hi c120613,
I think you made mistake with material settings or mesh units setting.Note that the inlet velocity 8.2678E+03 m/s.So the mach no is more and it results in Solver failure. |
