Bayard Morales
Rep Power: 17 ![]() |
Hi there.
I´m simulationg a kind of bubble column and would like to make it a little more sofisticated. At the top boundary - degassing - it is possible to plot the pressure profile. The highest pressures are, of course, found at the spot where the gas hits this boundary. Is there any way to make the mesh deform following this pressure profile? The goal is to, somehow, simulate the elevation on the liquid surface due the gas. So, where the pressure is higher, the mesh would deform. I´ve been working with this kind of flow, considering a domain bottom half filled of liquid and top half filled of gas, but it is a bit hard to deal with it, so I´m working with a degassing condition now. Any hint? Thanks! |
Rep Power: 144 ![]() ![]() ![]() ![]() |
It would be possible to do this as a deforming mesh but I suspect a free surface approach would be better. Can you do a free surface model rather than a degassing boundary?
I've read there are people doing that (single-phase simulation, and using a moving/deforming boundary to represent the free surface).
But I've never seen an example, and always wondered how do you calculate the movement of that free-surface boundary. And what are the limitations of this method relatively to doing a 2-phase free-surface simulation (assuming you don't care what happens in the gaseous phase). Cheers
bubble column, deform, mesh |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
Periodic Boundaries in GAMBIT!! | swetha | FLUENT | 1 | November 26, 2006 22:02 |
problems replacing old boundaries | Jared | Siemens | 4 | August 5, 2005 19:36 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 13:11 |
