November 23, 2009, 01:05 |
exhaust gas simulation
jaikrishna
Rep Power: 17 |
what is the procedure for turbine simulation of turbocharger?
my work is to to find the temperature/heat transfer distribution on the turbine housing surface and give the result as a input file for thermo-mechanical & stress analysis. when do we use mass fraction of gas & for my analysis whether i've to give mass fraction of gas? how do i calculate it? pls explain the difference between exhaust gas analysis with mass fraction and without mass fraction |
November 23, 2009, 04:23 |
Rep Power: 144 |
Sounds like you need to visit a library, you have to understand things like heat transfer and mass fractions before you can model them. And there is no way advanced concepts like this can be described in a forum posting.
Do some tutorials on rotating machinery modelling. CFX comes with quite a few in V12 so do them all. Also do all the tutorials on modelling mass fractions and heat transfer. |
Point the noob in the right way - IC Engine exhaust simulation | AndreF | OpenFOAM Running, Solving & CFD | 12 | December 16, 2009 05:04 |
Tracer gas simulation with CFX4.3 | CFX 4.3 users | CFX | 3 | August 15, 2003 05:38 |
air flow simulation in gas turbine enclosure | Frankie | FLUENT | 2 | December 28, 2001 22:54 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
1D simulation of unsteady gas flows in pipelines | Andrew Chernousov | Main CFD Forum | 1 | September 4, 1998 23:42 |
