Fluidized bed failure
Old   November 11, 2009, 12:42
Exclamation Fluidized bed failure
Carlos
Carlitos is on a distinguished road
I´m simulating a fluidized bed model. I'm carrying out this simulation with Ansys CFX 11.0 software but i'm not able to find out the cause of error in solver. Besides, the cfx5solver finishes with a crash file in the beginning of the iterations so i cant get a backup file in order to check how the model is being simulated. The error is the following one:
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow
Details of error:-
Error detected by routine POPDIR
CRESLT = ILEG
Current Directory : /FLOW/NAMEMAP
I've read in forums that this error means the simulation is diverging. In order to make the simulation more stable I have chosen all these options:
- a laminar model
- remesh again and again to improve the mesh quality,
- reduce timestep size
- reduce convergence criteria
- use the 1st order discretisation
- check my initial conditions
I don't know what to do to come across this error so if you kindly try to help me..Thank you in advance.
Carlitos
(I've also attached the txt file, if you want you can look at it)
Carlitos is offline   Reply With Quote
Old   November 11, 2009, 22:13
Try to add the physics one step at a time. Start off with a simple single phase flow, then add the physics in as small steps as possible checking everything works.
Old   November 12, 2009, 06:16
ckleanth's Avatar
George
ckleanth is on a distinguished road
you can add " backup file at start = t " in the EXPERT PARAMETERS section to test the IC
do not use the Kinetic Theory model but the standard gidaspow solid pressure model and small timesteps.
you dont need adaptive mesh before you even managed to get the model started, a uniform mesh with reasonable resolution is much preferred. try first the physics setup on a 2D model and as glenn said add a bit of complexity at a time.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   November 12, 2009, 13:30
Exclamation
Carlos
Ok, thank you ghorrocks and ckleanth. Let me try what you said to me.. If i cant solve the problem i´ll post again.
Carlitos
Old   November 23, 2009, 14:30
Exclamation Fluidized bed II
Carlos
Hi
I've added the physics little by little as you advised me and now i manage at getting a simulation with the following main characteristics:
- Laminar flow
- Gidaspow drag model (which includes Ergun and Wen&Yu correlation)
- None Kinetic theory
Although bubbles are created inside the fluidized bed, the problem is the maximum packing: I've noticed that the solid volume fraction can become greater than the maximum packing limit (which i've fixed previously). This should be impossible. I dont know how to overcome the problem. I've tried to set as initial condition a value a bit lower than the maximum packing, but it doesn' t work. What do you suggest?
Another problem i have is the use of Gidaspow solid pressure as you mention above. I don't know which values for compaction modulus use. Could you help me?
Thanks in advance,
Carlitos
Old   November 24, 2009, 20:30
ckleanth's Avatar
George
if you need more help with the model I would reccomend you to buy the gidapsow book.
ansys have compiled a custom executable for me to help with divergence. I suppose if you have a suport contract you can request them to make one for you. otherwise use a lot more smaller timesteps
Top 4 tips
Old   July 28, 2010, 15:28
Germán González Silva
germangsilva is on a distinguished road
Send a message via MSN to germangsilva
hi Carlitos
I'm doing studies of fluidization (gas-solid), I'm using cfx11 or 12, and applying LES, but I have great difficulty setting the program cfx, I ask your help please. my email is germangsilva@gmail.com
germangsilva is offline   Reply With Quote
Old   July 28, 2010, 15:54
Thumbs up fluidized bed - CFX
hello
I'm doing studies of fluidized bed (gas-solid), I'm using cfx11 or 12, and applying LES, but I have great difficulty setting the program cfx, I ask your help, please. my email is germangsilva@gmail.com.
with Regards
Old   July 28, 2010, 18:14
pannsave
pannsave is on a distinguished road
Hi Carlitos
I think you need not specify two domains for fluidised bed simulation, you can define initial condition for packed bed and freeboard regions using CFX Expression Language by specifying solid volume fraction with function height of column
Another point is you can still reduce time step in the range of 1e-6 and check the simulataion
especially when you incorporating kinetic theory of granular flow model for solid phase, use very smaller time step
pannsave is offline   Reply With Quote
restitution coefficient ofr fluidized bed T.Hariharanath FLUENT 20 November 20, 2018 15:28
how to define static bed height for fluidized bed mohamad CFX 6 July 28, 2010 15:46
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 15:42
Questions about gas-solid fluidized bed simulation Sinferm FLUENT 1 January 31, 2007 15:54
Bubbling Fluidized Bed reactor burning biomass Mattias FLUENT 6 June 8, 2004 03:53
