Fsi ansys cfx?
Old   November 11, 2009, 10:39
Default Fsi ansys cfx?
MoS.T
Mostafa.T is on a distinguished road
My problem is: Soving a transient flow in a straight and elastic tube.(fully developed velocity profile at inlet and pressure at outlet are my boundary conditions)
I follow all the steps which are included in the help, but I face a error message when I want to solve. It says you should refine your mesh in solid domain? how can I do that? Should I use an external mesh generator?
If it is possible please tell me about this problem expressively. Further, how can I find the discretized equations of the ANSYS CFX (both solid and fluid sides)?
Mostafa.T is offline   Reply With Quote
Old   November 17, 2009, 04:00
mactech001 is on a distinguished road
If you've installed ANSYS Workbench and CFX, you can try improving your mesh in ANSYS Workbench, and then import the Mesh into CFX. You can see this import option in the Project page. i've done this in version 11
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Old   March 15, 2010, 07:31
iol
iolanda
iol is on a distinguished road
I wont to implement a full developed inlet in ANSYS CFX 12. I have the *.csv file, that CFX-pre read without errors, I've selected the correwct local coordinate frame and selected the profile from the list of profile boundary set up. The problem is: when I click "generate data" an then "apply" nothing happens.
Can anybody help me?
iol is offline   Reply With Quote
Old   March 22, 2010, 06:53
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
hi i have problem as same as you.
feizaghaee is offline   Reply With Quote
Old   March 24, 2010, 09:26
Default hi
iol
iolanda
If you have only one coordinate frame you can simply untick the coordinate frame field in CF setup, boudary conditions, Basic settings and in your file don't write anything about Ref Coord Frame.
If you need more coordinate frame you have to define them both in CFX and in yous .csv file, choose the corect one in Basic setting and then you can check, using the plot option, if everything is ok! Good luck
Old   March 31, 2010, 11:16
feizaghaee's Avatar
moein
i've got 1 coordinate frame. i checked coordinate frame option but nothing happened. without coordinate frame the situation was as same as before. the values didn't generate.
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 15:26
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 07:40
Ansys CFX 11 FSI and ICEM Sheeko CFX 3 November 16, 2006 07:42
MFX - for FSI between Ansys Multiphysics and CFX? Zerocles CFX 1 June 5, 2006 09:23
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
