Error message CFX Solver
Like Tree4Likes
Old   September 24, 2010, 07:48
compFrac
salilharris2 is on a distinguished road
Your problem should be numerical instability.
The denominator consists of dx and dy terms which create instability when meshing is improper. The numerator consists of terms which contains terms like velocity, mass, temperature etc. When the values go beyond a certain limit, it destroys the stability of the system of equations.
Another way of loosing the numerical stability is when the continuity, momentum, energy and mass transport equations are solved together, the convergence of one equation depends on the equation above it. There can be convergence problems when all these equations are solved together.
In your case, one or more of your values are somewhere outside the limits. Try optimizing your values to get a numerically stable system of equations.
I hope this solves your problems...
salilharris2 is offline   Reply With Quote
Old   June 15, 2011, 10:49
Daniel Leite Oliveira
Daniel Leite Oliveira is on a distinguished road
I had the same error...
I've changed the Run Mode from MPICH2 Local Parallel to HP MPI Local Parallel and now it's gone
See you
crevoise and chaitanyaarige like this.
Daniel Leite Oliveira is offline   Reply With Quote
Old   January 15, 2013, 10:47
Default Error message CFX Solver
  #23
ali
hota is on a distinguished road
this error message means a divergance in your solver, mostly cause of bad configurations in your presolver part, some times it happen cause of wrong or bad Boundary Conditions, bad B.C. some times produce zero denominators and make the solver diverge at the begining, my experiance is about Opening BC in CFX, where i chose Opening pressure and Dirn, and in direction part i chose cartesian components, then i entered a direction which was totaly tangent to my Boundary, so when i started the solver, it showed me Code1 or Code 255 as divergance alarm, look at your BC more carefully,
regards, ^_^
hota is offline   Reply With Quote
Old   November 29, 2013, 17:46
Default Fixed the issue
  #24
PYJG is on a distinguished road
I had this error and was able to fix it....It was caused by antivirus deleting the mpid.exe file from the installation directory. Make sure this file exist there. Thanks.
PYJG is offline   Reply With Quote
Old   November 30, 2013, 05:36
Wow, that is one evil antivirus you have there.
Old   July 3, 2015, 11:32
Default CFX does not produce .res file when stop the run
  #26
dengemunzur is on a distinguished road
Hi to all,
I am having a problem with CFX. When I try to stop run, CFX ends it but does not produce a result file. The problem is that everything goes well, the solution converges, also monitor point Iadded. when I stop the run, I face the warning "the cfx solver for system fluid flow did not produce a results file".
I tried to find a solution but could not achieve. By the way, I work on workbench.
Any idea?
Thanks
Best regards
dengemunzur is offline   Reply With Quote
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 17:42
divergence in CFX solver Tanveer Ahmad Rubani CFX 1 February 24, 2009 17:19
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 06:43
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 23:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 23:54
