Rotor stator problem: Discontinuity across the interface
Old   November 10, 2009, 23:42
Unhappy Rotor stator problem: Discontinuity across the interface
Bubka is on a distinguished road
Hi!
I'm simulating a mixing vessel with impeller, baffles, etc. I've simulated it using frozen rotor as well as transient rotor stator. The flow field itself looks good (if I look at velocity in stationary frame).
But I am also solving a scalar equation (I have an inlet where a tracer comes into the vessel and I am looking at how the tracer mixes with the rest of the fluid). If I look at contour plots of this tracer, I see a discontinuity across the interface. This is presumably because of the different frames of reference.
How can I account for this discontinuity in CFX-Post? CFX-Post has "Velocity" and "Velocity in stationary frame". Does it have a similar feature for additional scalar equations?
Thanks!
Bubka is offline   Reply With Quote
Old   November 11, 2009, 06:07
If you use frame averaging then you will get discontinuities across the interface. But you are using TRS and frozen rotor and they do not do the stage averaging. The tracer concentration should not be affected by the frame of reference you should be able to view it directly and it should be continuous. Are you sure your simulation is fully converged and the mesh is adequate?
Old   November 11, 2009, 08:57
Hi Glenn!
Thanks for your reply. Yes, the mesh and convergence are ok. Not perfect, as the geometry is pretty complicated.
I think I'll do a test with a simple geometry and see if the same problems come up.
Thanks again.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Pressure discontinuity across the interface in LesInterFoam andi OpenFOAM Running, Solving & CFD 1 August 18, 2008 08:06
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
