Free surface is below than expected..results are not good
Old   November 15, 2009, 18:36
my length scale is 50 mm!
That may well be quite large, but of course a bit meaningless without the rest of the bits to make up relevant non-dimensional number. Do you know the Re, We or any other relevant non-dimensional number for your flow?
Why do you think surface tension is important? It usually is not significant for large length scales.
If you want to make surface tension a function of temperature then obviously you need to model the energy equation. This will add significant complexity and instability to the model, only do this if its contribution is significant.
I recommend you start with constant surface tension (and isothermal) before tackling the more difficult varying temperature/surface tension simulation.
The reference in the documentation describes how the compressive discretisation scheme find the free surface. Also I think there a description of the surface tension approach in the documentation.
Old   November 16, 2009, 09:45
fab
fab is on a distinguished road
hi are you sure that i need the energy equation? it is q=n*delta(h)?
i have a laminar flow so i think it is RE as non-dimension number.
how did the solver know that i actually declared the surface tension by the expressions?
the surface tension-curve as function of the temperature is that what i have to implement!so itīs very important to me to know how the surface tension is changing during the flow.
i have first of all a water film on a platt .
this platt has 2 different temperatures(2 bottoms),my flow is laminar.
later i will modelling a polymersolution!
fab is offline   Reply With Quote
Old   November 16, 2009, 19:03
You don't know what the energy equation is, you don't know what the Re number is.... Sounds like you need to learn some basic fluid mechanics. I would forget about modelling surface tension and polymerisation until you know the basics.
Old   April 8, 2011, 01:17
Default different result
  #24
Iqbal, Muhammad
bha2l is on a distinguished road
dear all,, what do you think,,
i ran free surface flow on ship at 7 knot and 9 knot,,
and the result of force x on ship on 7 knot in negative but on 9 knot is positive.. which is true..??
please answer,, and thanks before..
bha2l is offline   Reply With Quote
Old   April 8, 2011, 01:41
Probably neither.
Please do not hijack threads. Start a new thread for a new question.
free surface, unsatisfactory results
Bubblze induced turbulence at a free surface ???? thomas Main CFD Forum 6 April 21, 2012 10:48
Free surface height v/s time ashish CFX 2 October 4, 2005 15:13
free surface display novice Siemens 5 August 4, 2004 02:07
Free Surface Flows / Ocean Waves / Far-field boundary conditions Sundar Prasad Main CFD Forum 5 May 4, 1999 11:25
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 19:47
