November 1, 2009, 06:13 |
Underwater turbine
Ian Milne
I am considering modelling a tidal turbine in CFX to look at the effect of waves and undertwater turbulence on the blade loads. As a start I think it would be best to seperate the two phenomena and have two models, one for waves and one for turbulence. I would like to use my results in validate a simplier dynamic inflow blade load solver. I had planned to start off looking at simple (non breaking) waves. Due to the computational time I think it may be best to just analyse a couple of wave heights, frequencies and depths. Has anyone had experience with modelling a transient problem for an underwater turbine? I am just concerned with the time it will take to obtain a solution and whether it is feasible. Any comments would be appreciated. Thanks. |
November 1, 2009, 06:51 |
Rep Power: 144 |
I would be very surprised if anyone else on the forum has modelled this type of turbine. But you never know your luck.
As for whether the model is feasible - this obviously depends on the resources you have available (both computational and your time and skill) and the importance of the results. If your model identifies a key design parameter which has otherwise been missed then it is likely your models will be very useful. But in my experience, to get a complex model to a point where it is a useful design tool requires time, attention to detail and a good knowledge of the physics of what is going on. So start simple and validate each extra bit you add along the way with experimental or analytical results. |
free surface flow, transient effect, turbine, waves |
Water turbine CFD modeling | Peter | Main CFD Forum | 7 | April 4, 2016 03:31 |
Sliding mesh vs MRF in axial turbine simulation | Vito | FLUENT | 3 | December 21, 2011 05:57 |
Meshing Volume in Gambit for a water turbine | Zaqie | FLUENT | 1 | July 24, 2009 02:25 |
Flow study through Turbine Blade passage | Subrata | FLUENT | 1 | May 4, 2007 12:28 |
turbine noise | naser | FLUENT | 0 | December 3, 2004 14:37 |
