October 24, 2009, 21:47 |
Residence time distribution, please help
Tshepo
Rep Power: 17 |
| ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | USER ROUTINE: User Output could not be loaded. Please check the L- | | ibrary Path, Library Name and Calling Name. For FORTRAN user rout- | | ines, the Calling Name should be in lower case. | | | | | | | +================================================= ===================+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine UR_REGISTER | | How do I solve this problem, I am using Windows XP, ANSYS 11 |
October 25, 2009, 06:17 |
Rep Power: 144 |
Doesn't the error message tell you exactly what is wrong? In your fortran routines you are using a calling name which is not in lower case. Convert it to lower case. Alternately it can't find the library path, name or calling name.
October 25, 2009, 08:38 |
Reply to previous message
Tshepo
Rep Power: 17 |
Thanx ghorrocks
I have changed the calling name to lower case but still i seem not to get passed the problem. do u have any idea of fixing the library path error since i think this is the major error. |
October 25, 2009, 08:43 |
Tshepo
Rep Power: 17 |
just as an add on to my problem. I tried copying the user_output.F fortran file to a new folder and directed the user routine to it but i get the following error:Unable to find library winnt/user output.dll on path "D:/User For- tran". can u please help me overcome this error
October 27, 2009, 16:44 |
Rep Power: 21 |
Sorry if this is a silly question, but did you compile the fortran?
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
How to get residence time distribution? | bigfans | FLUENT | 0 | April 27, 2009 10:39 |
residence time | pilar | FLUENT | 0 | January 13, 2004 13:26 |
Residence Time Distribution | rajeev | FLUENT | 11 | July 26, 2001 14:49 |
