October 21, 2009, 11:24 |
Moving mesh with butterfly valve
Rep Power: 17 |
Hello. I have been modelling a butterfly valve on cfx 12. I try to make the valve rotate by some range of angles but i cannot make it since in the options there are only displacement and location. I used displacement under cylindrical coordinates and i managed to get deformation around the axis i wanted but half the valve was going up and half down, ie not rotating. Any ideas?
October 21, 2009, 18:19 |
Rep Power: 144 |
Do I understand you by saying the valve does not rotate (eg a throttle butterfly in a car) but has two sections which rotate in different directions to throttle the flow? An image might help explain what you mean.
Assuming you are talking about a twin-pivot butterfly, I see several options: 1) Use one rotating frame of reference for the top valve and another for the bottom. 2) Use the immersed solid feature 3) Use deforming mesh - this would be quite difficult to do and it does not appear to be the best option. |
October 21, 2009, 18:38 |
Rep Power: 17 |
No the valve is a single one. I just tried to describe it as two parts each on one side of the axis. Anyway, I looked further into it and now what i did was to create a second domain (solid) which is the valve. I made a domain interface between the fluid and the valve and now i have a different problem. I use moving mesh and at the same time try to rotate the domain of the valve. Only that rotates though, not the fluid domain... What i have looks mich like the bottom bit from this page. http://www.ansys.com/assets/tech-bri...oving-mesh.pdf Thanks |
October 21, 2009, 22:39 |
Rep Power: 144 |
I see, you are modelling a normal butterfly valve then.
You do not want to model the valve as a solid. That will not work (unless you use the immersed solid feature). My recommendations are still unchanged: 1) Use a rotating frame of reference for the valve and connect it to the rest of the passage with a GGI OR 2) Use the immersed solid feature OR 3) Use a deforming mesh. Which is the best option will depend on exactly what you are modelling. |
October 24, 2009, 10:22 |
Rep Power: 17 |
Okay I'll see what i can do. Thanks lot
November 1, 2009, 07:30 |
Xue-Guan Song
Rep Power: 17 |
ghorrocks is right,
you can build two domain, one is flow field without valve, and the other one is a circle domain containing butterfly valve, then connect them with GGI. and then, what you should do is write a CEL to control the domain containing valve to rotate a expected angle. some details you can refer to a journal paper: <Dynamic analysis of three-dimensional flow in the opening process of a single-disc butterfly valve> http://www.springerlink.com/content/vq5472u30686p9w6/ |
May 28, 2010, 06:54 |
butterfly valve
euzinho
Rep Power: 16 |
Hi dear
I am trying to solve the same problem but using fluent, and I donīt have any idea how to do in order to get it done... How can I make this valve rotate? any help? thanks in advance |
May 28, 2010, 06:58 |
butterfly valve
euzinho
Rep Power: 16 |
so, I wonder how to rotate the valve thanks |
May 28, 2010, 08:57 |
#9 |
Rep Power: 144 |
You are using Fluent. Try the Fluent forum.
February 8, 2011, 01:20 |
butterfly valve vane movement
#10 |
Archana
Rep Power: 16 |
I am using solid works flow efd..
I have trouble in moving the vane to various location.. how do we calculate the CV torque and other values for butterfly valve any information would be of great help |
February 8, 2011, 06:15 |
#11 |
Rep Power: 144 |
What is flow efd? Sounds like you are on the wrong forum too.
February 8, 2011, 08:25 |
Butterfly Valve
#12 |
Archana
Rep Power: 16 |
its flow simulation..
its an add on in solid works. Which is used for simulation ... A detatiled "How to do CFD analysis in a butterfly valve ?" is what i am looking for.. It would be kind of you if you could help me... Thanks and regards Archana |
February 8, 2011, 18:22 |
#13 |
Rep Power: 144 |
In that case you definitely have the wrong forum. This forum discusses CFX. Try the general CFD forum.
February 24, 2011, 15:03 |
#14 |
ALEJANDRO VELASCO
Rep Power: 16 |
Hi, I use a solid immersed to simulate a butterfly valve, and I He obtains good results, however I have a doubt why that seems to be immersed solid permeable (part of the fluid is able to pass through it)?
February 24, 2011, 20:07 |
#15 |
Rep Power: 144 |
Immersed solids work by using a momentum source. You will need to adjust the momentum source scaling factor to stop the flow going through the solid.
February 25, 2011, 00:16 |
#16 |
Archana
Rep Power: 16 |
IS immeresed solid another software ? what are the steps involved in doing a cfd analysis in a butterfly valve
February 25, 2011, 06:40 |
#17 |
Rep Power: 144 |
No, immersed solids is part of CFX. There is a tutorial example of how to use it.
Moving Mesh | David | Siemens | 16 | July 27, 2009 10:52 |
Moving mesh | Martijn | CFX | 3 | November 26, 2008 22:46 |
VOF with a moving mesh | Jeremie | FLUENT | 1 | November 26, 2008 09:55 |
moving mesh | haribalan | CFX | 1 | June 6, 2006 09:26 |
C4 = 1 for Moving Mesh | Xobile | Siemens | 2 | January 18, 2005 06:22 |
