October 15, 2009, 03:07 |
Speed of sound (mesh movement)
Ali
Rep Power: 16 |
I used bulk modulus approach for defining the density for the model of piston movement.The bulk modulus is as a function of pressure (table below), then I used an expression for calculating densiyt as a function of variable bulk modulus and constant speed of sound (1500 m/s). Table: bulk modulus versus pressure at 68 F degree for water (from fluid mechanics book)
Pressure (Psi) Bulk modulus (Psi) .................. ........................ 15 ------------320,000 1,500 -------- 330,000 4,500 ---------348,000 15,000 --------410,000 But, from the slover, i observed that the speed of sound is equal to (578) in the average scale information, i think that is not true. Could someone help please? if it is not the right way for defining the bulk modulus apporach, could someone tell me how to define it??? Thanks in advance. |
October 15, 2009, 06:35 |
Rep Power: 143 |
Sounds like your density/pressure function is wrong. Or the average scale information is misleading you. Check in detail in CFD-Post what the acoustic velocity is.
October 15, 2009, 09:12 |
Ali
Rep Power: 16 |
Hallo,
Thanks for your answer. I cheked the wave's velocity in post, it is also 578 (m/s). The density/pressure function that I used is: c=(K/density)^0.5 C: speed of sound (1500 m/s) in water. I used constant value. K: Bulk modulus, function of pressure. Any suggestions or ideas?? |
October 15, 2009, 18:48 |
Rep Power: 143 |
Can you post your CCL?
October 16, 2009, 04:29 |
Ali
Rep Power: 16 |
Hallo,
Here is the expression: (BulkModulus(Absolute Pressure))/((1500 [m/s]*1500 [m/s])) BulkModulus: is function of pressure for the table in my post messege 1. I could also send you the definition files, if you have time to have a look, please just give me you email address, Thanks |
October 18, 2009, 07:12 |
Rep Power: 143 |
No, post the entire CCL. I don't have the time or inclination to check people's def files.
CrankNicholson returns wrong dimensions and sound speed when mesh is moving | lillberg | OpenFOAM Bugs | 6 | May 4, 2009 17:53 |
Abt: the speed of sound in incompressible flows | jinwon park | Main CFD Forum | 3 | August 21, 2008 20:44 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 12:16 |
How to execute a bidirectional mesh movement( FSI) | Ganesan | CFX | 0 | April 19, 2007 08:01 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
