Executable for cfx
Old   October 10, 2009, 11:11
Default Executable for cfx
daniellw is on a distinguished road
I am new to cfx and I am trying to create an executable which could feed inputs design of axial flow pumps into cfx for cfx to solve . So far i can't seem to call ansys directly within matlab. I wonder if this is possible with any other programming languages like say c++ or c? Also is it possible to create/compile an executable which could feed inputs into cfx for it to generate a 3d model without using any cad tools?
daniellw is offline   Reply With Quote
Old   October 11, 2009, 06:10
Are you looking to feed the inputs in as just a run set up or as a dynamic link during solution. The first option can easily be done using perl/shell/batch scripts and the second can be done with user fortran.
Old   October 11, 2009, 11:08
Thanks for the reply. For the moment, I want to make it as a run setup for an experiment.
What i am trying to do is to to skip all the repeating routines of selecting new simulation > turbomachinery > machine type - pump, component def, etc and go straight to the solver and simulating the flow.
Is there any webpage or online helpfiles with a list of script commands for cfx11?
Old   October 11, 2009, 18:42
Look in the CFX documentation. You can run pretty much all the CFX suite from the command line using scripts so that should do what you want.
error: post processing only executable Ralf Schmidt FLUENT 1 December 28, 2019 06:27
Tutorial 8 - Unable to locate import executable Kambusha CFX 0 April 10, 2009 08:58
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
Fortran90 (creating executable by using libraries) Ravi Main CFD Forum 0 September 27, 2004 23:34
create executable and batch file in text mode Johan Siemens 2 July 23, 2000 13:02
