Making Lines in CFX
Old   September 30, 2009, 10:40
Default Making Lines in CFX
Scott Nordsen is on a distinguished road
I am an experienced Fluent User but new to CFX.
I have a case that I want to run in both.
Running in CFX was easy (took < day to setup and run).
Post-processing is little more foreign.
In fluent I can make lines (~40) by generating a journal file and reading it in.
In CFX, I guess I could do the same but for now help with the following would suffice.
Question:
In CFX Post (GUI), command line editor what is the equivalent to
line line-name x0 y0 z0 x1 y1 x1
Thanks
Scott Nordsen is offline   Reply With Quote
Old   September 30, 2009, 20:31
What is a "line"? What do you want to do with it?
Old   September 30, 2009, 20:36
ckleanth's Avatar
George
ckleanth is on a distinguished road
i think that you had little response purely because your question is not very well defined. can you elaborate what you want to do?
the equivalent of journals in cfx is scripting and can be done either directly using only cel expressions or a mix of perl commands with cel.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
