September 22, 2009, 14:14 |
Error in conjugate heat transfer
HI ALL,
Bad expression value 'OutletTemperature' detected in parameter 'Opening Temperature' in object '/FLOW:Flow Analysis 1/DOMAIN:fluid_domain/BOUNDARY:OUTLET /BOUNDARY CONDITIONS/HEAT TRANSFER'. CEL error: The following unrecognised name was referenced: outflow.
sivaramakrihnaiah |
September 22, 2009, 19:19 |
Rep Power: 144 |
Isn't it obvious? The expression "OutletTemperature" is using an undefined variable "outflow". The error message seems pretty clear to me.
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 16:55 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 16:41 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 10:51 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Conjugate heat transfer (vs) periodic boundary | mp | FLUENT | 1 | January 13, 2003 02:38 |
