Question Regarding Convergence and Time Step Selection |
September 12, 2009, 16:56 |
Claudio
Rep Power: 17 |
I've been reading practical tutorials and seen that a reasonable target value for RMS residual for steady state simulations is 0.0001. However, I'm not quite sure for transient problems what is an appropriatte target value. I understand transient simulations are solved by computing a steady state solution for many discrete points in time. Each steady state solution is iterated through a number of inner loops called “coefficient loops”. What is a reasonable RMS target for each time step? I've read that 3-5 loops should allow you to reach convergence. I've noticed CFX by default monitors the RMS for each timestep. If the RMS value for that timestep is above the target, does that mean the solution is not converged? Should I wait until all monitored RMS quantities are below the target for all time steps from there on to be confident about my solution? What other quantities are good practice to monitor in order to trust the obtained solution? Thanks! |
September 12, 2009, 17:40 |
Jules Bell
Rep Power: 17 |
I usually use a target value of 1e-4 for the MAX Residual.
And yes, if the residual is higher than your set convergence limit, then the solution for that timestep has not converged within the maximum number of coefficient loop iterations. |
September 13, 2009, 02:45 |
#3 | ||||||
Rep Power: 144 |
September 14, 2009, 11:31 |
Claudio
Rep Power: 17 |
Thank you very much for your replies. Glen, I'm not exactly sure how to perform that sensitivity analysis. What you mean is that I should see how my answer varies as I use different target values for RMS? As long as the answer doesn't change significantly as I increase the target RMS, I could use that higher value (or lower, eventually), right? |
September 14, 2009, 19:39 |
#5 | |
Rep Power: 144 |
Time step size and max iterations per time step | pUl| | FLUENT | 31 | October 23, 2020 23:50 |
Changing deltaT of current time step | olwi | OpenFOAM Running, Solving & CFD | 1 | April 30, 2009 05:55 |
false time step implementation for steady state | Kushagra | CFX | 1 | June 22, 2008 20:06 |
Time step - Turbulence - Convergence | Camilo Costa | CFX | 0 | March 13, 2008 15:23 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
