convergence problem for opening BC (entrainment) |
September 7, 2009, 13:23 |
Rep Power: 17 |
Hello everyone!
I'm having convergence problem using opening BC with static pressure (entrainment) condition. My other BCs are inlet and outlet. My model is two-phase compressible. I've played around the automatic timescale and local timescale but I still have poor convergence. If I use inlet instead of opening-entrainment, my simulation converges. Do you have any suggestion guys? Entrainment BC is more suitable for my model. Thanks a lot! |
September 7, 2009, 21:50 |
Rep Power: 144 |
The entrainment BC is much harder to converge so if you are having problems converging then I would not use it. It might be better to move your boundary further away so you can use the simpler non-entrainment boundaries.
September 7, 2009, 22:04 |
Rep Power: 17 |
Thanks a lot for the advice Sir Glenn! Do you think entrainment BC is more mesh sensitive than other BC? Thanks.
September 8, 2009, 07:49 |
Rep Power: 144 |
It probably is. It is certainly harder to converge in general than the normal BCs. That is why if possible I prefer to move the boundaries further away from the region of interest and use simpler BCs instead.
September 9, 2009, 22:29 |
Rep Power: 17 |
I got it sir. Thank you so much again!
compressible, convergence, entrainment |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
convergence problem | alexandre | FLUENT | 2 | June 14, 2007 15:31 |
convergence problem | ammi reddy | FLUENT | 1 | March 28, 2007 18:01 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 23:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 01:24 |
