How to set domain translation and rotation in CFX
Old   September 2, 2009, 23:25
Default How to set domain translation and rotation in CFX
Ricardo Halfeld
ricardo.halfeld is on a distinguished road
Hi everybody,
I'm currently trying to make a 2D simulation of a wing profile rotating about an axis somewhat far from it AND around it's own axis. My current approach is to have a static square mesh with a hole in it, so in this hole goes another circular rotating mesh which also has an excentric hole where the wing profile mesh goes. All meshes are connected with GGI Interfaces.
The rotation of the second mesh can be easily defined by clicking domain containing it's parts and setting the domain motion to rotation. But what about the smaller domain containing the wing profile? Using the same setting I'd get it to move around it's primary axis of rotation (the axis of rotation of the second mesh), but not around it's own axis. Any ideas?
I have an Expression that defines the X and Y coordinates of the center of the smaller domain and another one with it's angle of rotation, both funtions of time, but I can't find out how to link these expressions to the domain motions.
ricardo.halfeld is offline   Reply With Quote
Old   September 2, 2009, 23:42
Some options:
1) Model the airfoil mesh using a normal deforming grid (not a rotating domain) and use a CEL expression to move the mesh how you wish. You then connect everything up with GGIs as normal.
2) Just have a static background mesh and use the new V12 immersed solid functionality. This would be quite easy to do, but it does mean that you will not be able to have a nice boundary layer grid on the airfoil. If a good boundary layer grid is important then this approach is not recommended.
Old   September 4, 2009, 10:06
Ricardo Halfeld
Glenn, thanks for your input. The boundary layer is indeed important and making a refined mesh throughout the blade excursion path would be "too expensive". And the guy orienting my project has had bad experiences with deforming mesh in forced oscilations.
I can't believe there's no way to define the mesh position as a function of time as well as rotation with CEL. I believe this is the simplest way to run this simulation. Doesn't anyone have a clue on how to do it?
Old   September 5, 2009, 03:24
OK, if you need a good boundary layer mesh then you only have one choice - being a deforming mesh. Properly implemented it should work fine.
Yes, you can do it - using deforming mesh.
If you look in the tt.txt file and/or the RULES file in <CFXROOT>/etc you will see that translating meshes is in there. However as it is not documented (not even as a beta feature) so it probably either is only in the CEL and not the solver or doesn't work properly. I don't know, I have never used it. You will need to talk to a support person to get a definite answer on this.
Even if you can get a combined rotating and translating mesh thing working then I guarantee it does not have the full equations of motion in there, meaning some accelerations of the frame of reference are not correctly modelled. So to be sure I recommend you go to a deforming mesh as that has all this stuff covered.
Old   September 6, 2009, 09:40
Ricardo Halfeld
OK. I will.
I never used deforming mesh, so I will try some tutorials. Thanks for all the support!
Old   September 7, 2009, 08:27
It would be great if you could post the response you get from CFX support, then we can all learn a bit.
Old   September 8, 2009, 12:40
Ricardo Halfeld
I will. I tried getting in contact through Ansys' website. I had to fill some forms and they should contact me soon... that was 3 days ago...
Is there a support email address?
Old   September 8, 2009, 19:22
ckleanth's Avatar
George
ckleanth is on a distinguished road
well there is but don't you have an ansys sales contact through whoever sold the software to you/company/university?
bear in mind if your oranisation does not have a support contract.. well you will wait for quite a long time...
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Translation and rotation for a moving wall Stéphane Champmartin FLUENT 1 November 28, 2006 11:57
Relief Plots in CFX Michael CFX 15 June 30, 2006 09:01
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
