Sergio Brett
Rep Power: 16 ![]() |
Hi all,
I need to make an external subroutine to the ansys cfx solver, in order to make some operations that the ccl or expression does not allow me to do. I am traying to makes the tutorials 9, but I can't compile the file that as the tutorial says. When i try to compile the file using the command editor I get the following message. "CCL parser failed with message: Perl Syntax errors detected: cfx5mkext failed at (eval 45) line 1". This is the first time i try to do it, I just installed the Ansys in my computer and I don't know anything about compiler or Fortran, Could anyone explain me what should I do in order to complete the tutorial and learn about programming with fortran Thanks |
#2 | |
Jack
Hi Sir,
Take a look yourself ![]() http://www.cfd-online.com/Forums/cfx...-compiler.html http://www.4shared.com/file/72198900...tionpart1.html http://www.4shared.com/file/72199871...tionpart2.html With kind regards, Rogerio. Quote:
#3 | |
Rep Power: 17 ![]() |
Sergio Brett
Hi.
The tutorial 9 can be done with CEL expression, but there is an opcion to do it compiling a file called PipeValve_inlet.F, at this point is where I get the error message. I don't have installed any fortran compiler in my pc, now I realized that this is the problem, I am going to install it and then try again. Thanks |
GETVAR SUBROUTINE for additional variable in CFX | Tuks | Main CFD Forum | 0 | November 8, 2005 06:13 |
CFX 4.4: NAG Library Link to CFX subroutine... | Robin K | CFX | 2 | September 21, 2005 10:40 |
SEEK FOR 'CFX Subroutine Archive' | youngan | CFX | 2 | August 30, 2003 06:05 |
discuss user subroutine in CFX | Anicorl | CFX | 6 | August 25, 2003 17:01 |
CFX User Subroutine Archive | David Creech | Main CFD Forum | 0 | March 17, 1999 12:41 |
